Old 03-10-2004, 10:24 AM   #1
halyoder
halyoder is an unknown quantity at this point
Send a message via AIM to halyoder
how to test a coil pack
i have a redtop sr20det and i was driving my car the other day and my friend told me that it sounded like my car was running on 3 cylinders. so i pulled my plugs and found out that one of the cylinders is not working the spark plug look brand new. i smelled it and it had some gas on it so i think that in not get a spark. so my ? is how do you test a coil pack. also could my igniton chip be causing is problem.
halyoder is offline   Reply With Quote
Old 03-10-2004, 10:54 AM   #2
Steeles
Steeles's Avatar
Steeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura about
Send a message via AIM to Steeles Send a message via Yahoo to Steeles
chit I wish the search on FA was working... Planb (not the newb from miami) posted the page from the FSM. basically you need a multimeter but I forgot which of the three pins to test.... lemme look around see if I saved it/printed it.. or download the FSM for the S14 and look in the electrical. the procedure is in there. coilpacks are the same so there ya go
Keeping it Godzira bishes.
So I murdered another turbo
Steeles is offline   Reply With Quote
Old 03-10-2004, 11:06 AM   #3
Kid Zelda
Kid Zelda is an unknown quantity at this point
Send a message via AIM to Kid Zelda
Coil is easy to check
You want to disconnect the coil from the hanress. Check resistance between terminal 1 and terminal 2, you should have 1 ohm of resistance.
good luck
Kid Zelda is offline   Reply With Quote
Old 03-10-2004, 02:47 PM   #4
halyoder
thanks for your help guys. i hope it is just the coil pack.
Old 03-11-2004, 08:04 PM   #5
Ryan of Velocity
Ryan of Velocity is an unknown quantity at this point
Send a message via Yahoo to Ryan of Velocity
Screw that. Shove a screw driver up there and see if you get some arc! lol. Just kidding, don't do that.
Works Yamaguchi
www.worksyamaguchi.com
8253 Indy Lane
Indianapolis, IN 46214
(317) 273-8809
Ryan of Velocity is offline   Reply With Quote
