Old 10-05-2012, 02:14 AM   #1
Po_31
Po_31's Avatar
Trader Rating: (28)
Feedback Score: 28 reviews
SR wastegate vacuum to hotpipe or outlet pipe
first of all i have a sr20det
I would like to know if anyone has actually installed a hose fitting or something else into their hotpipe as a means for the vacuum to the wastegate? i seen some people on different forums drill a 1/8 npt to the turbo outlet pipe instead, would either one of these work which would you choose
thanks
Old 10-05-2012, 02:30 AM   #2
s14boy
Trader Rating: (26)
s14boy is an unknown quantity at this point
Feedback Score: 26 reviews
just get a t-hose barb connector and cut on of your vac lines and run it from their. its simple no need to drill anything.
s14boy is offline   Reply With Quote
Old 10-05-2012, 10:15 AM   #3
compactfean
compactfean is an unknown quantity at this point
I don't know why.everyone thinks its ok to t off a vacuum line. internal waste gates aren't supposed to see vacuum and is clearly shown in vacuum diagrams. weld in a nipple to the hotpipe, that's how I have mine setup.
compactfean is offline   Reply With Quote
Old 10-05-2012, 10:55 AM   #4
Po_31
Po_31's Avatar
Trader Rating: (28)
thanks alot
just making sure i did right the first time
Old 10-05-2012, 02:13 PM   #5
waxball88
waxball88 is an unknown quantity at this point
This
If you want to run it to the manifold just run a one way check valve. Wastegates need a BOOST source.
Hotpipe/compressor housing
waxball88 is offline   Reply With Quote
Old 10-06-2012, 09:54 PM   #6
silviaNC
silviaNC's Avatar
silviaNC is an unknown quantity at this point
sorry to get in the thread but this is how I have mine set-up. do I need to change anything on it?
I'm using option 2. is it right?
silviaNC is offline   Reply With Quote
Old 10-07-2012, 01:32 AM   #7
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
i drilled a hole one of the couplers on my hotpipe then used this for my actuator
Turbo Quick Tap Fitting for Boost Source
works great. the closer the line to the actuator the faster it responds
