![]() Join Date: Dec 2001
ok , i'm kinda new to this but have big plans for the future , but first , where is the #### speed limiter on my car and how do i get rid of it safely?
'90 240sx fastback |
Autox Technician
I'm not sure if there is a way for SOHC's to disable the speed limiter. At least, it isn't documented. For info on the DOHC speed limit cut check
http://www.240sx.org , it's in the FAQ. Maybe you can see if your ECU has the same wire color/stripe and position. If it doesn't have both, I wouldn't mess with it. The other way to get rid of it would be the Apexi Rev/Speed meter. At least I've heard it intercepts the speed signal and disables the governor by "tricking" the ecu. |
<a href="http://www.zilvia.net/forum/topic.cgi?forum=1&topic=1619&start=0
I" target="_blank">http://www.zilvia.net/forum....t=0 I</a> just did it man make sure u cut the right wire and u will be ok although im not sure about this for the SOHC mine is a DOHC s14 |
AutoX Junkie
I cut that wire on the ecu and now instead of the engine just quitting at 5100rpm (5th gear) it starts vibrating violently (rev limiter) at 5200rpm. I does the same in fourth gear (different rpm limiter--6300? forgot). So I probably gained a whole 3 mph top speed from doing this. Where is that backup limiter? And how are you (240booster) hitting 125?
#5 |
welll urs is an s13 so maybe a little different than my s14 but im hitting the same 5th gear rev limiter ur talking about at about 5500 rpm i think and my speedo only goes to 120 so im guestimating im topping out at about 125 now .... there is a FAQ at 240sx.org about that 5th gear rev limiter u have to disconnect some plug at the tranny i think and something else check it out ... then the sky should be the limit .... lol untill u blow ur motor :-P
