Old 10-18-2012, 10:46 PM   #1
Supergoji
Supergoji's Avatar
Supergoji is an unknown quantity at this point
Send a message via AIM to Supergoji
Wheels, SR, VVL, KA, Z32, Z33, OEM & aftermarket
Body Kit
S13 BN type 2 body kit SOLD
Wheels/brakes/hubs
Front 17x8/ Rear 17x9 work stitch wheels $600
Front 18x8.5/ Rear 18x9.5 SSR integral A2 $1,400
front 16x7.5/ rear 16x8.5 $250 Z32 twin turbo set
all around 16x8.5 Z32 Twin turbo wheels Chrome $450
240sx 5 lug conversion $250
180sx brakes x2 $75 each
S13 4 lugs front hubs $15
S13 front knuckles $20
350Z items
cloth seats with s13 rails $350
Z32 items
intake
Upper and lower twin turbo plenum $150
Custom 2.5" intercooler with dual inlet/outlet $200 (great for 2jz, RB, VG swaps)
Throttle bodies $30 each
N62 Twin turbo MAF $50
Engine/accs
Twin turbo under drive pulley $70
Timing covers $100
2 sets of Twin turbo heads $220 each set
1 Set of non turbo heads $150
2 Twin turbo blocks w/cranks, pistons, rods $300 each block
2 set of 4 Cam Gears$40 each set
1 set of 4 cams 5spd $200
1 set of 4 cams auto $180
2 twin turbo Power steering pumps w/ brackets $50 each
electrical
EFI harness connectors w/ pigtails $8 per
90 PTU $30
3 twin turbo alternators $50 each
tons of coilpacks $15 per
Trans/Clutch/Diff
Non turbo RPS flywheel/clutch/pressure plate $380
5 spd trans $200 Great for RB25 swaps
Twin turbo Rear end, brakes, suspension, wheels, diff etc. $450
Exhaust
2 sets of twin turbo manifolds $30 each
Specialty Z 2+2 catback $500
audio
Zenclosure for 10'' sub on driver side $60
500 wat Amp $60
Tons of interior parts
Fuel
1990 fuel rail $40
old style Nissan side feed
6x 270cc $180
6x 370cc $220
New style side feed
6x 370cc $350
I have tons of interior Z32 items, all interior panels I have are Charcoal (black)
240/180 items
KA
Engine
KA starter $25
#10 ecu 5spd $30
3x KA coils + ignition $25 each
KA24de Throttle body $25
oil pan sold
plug wires $5
Power steering
2x PS resi $30each
Transmission
Mount $10
VVL
SR throttle body $20
IACV $20
water sensor housing $5
SR20DET
oil pan x2 $20 each
oil pan baffle x3 $5 each
crank baffle x2 $5 each
water pump $sold
throttle body sold
thermo outlet x2 $5 each
s13 SR water neck $5
thermo housing x3 $5 each
water temkp sensor housing x2 $25
fuel rail sold
exhaust mani x2 $40 each
clutch fan (minus the fan just the clutch part) sold
water pump pulley sold
dipstick tubes x2 $5
cross over tube $5
oil catch can OEM x2 $15 each
intake manifold bracket $5
knock sensor x3 $20
oil return tube $5
power steering mount bracket sold
alternator mount adjuster $5
timing chain tensioner x3 sold
oil filter housing x3 $15 each
clutch slave $5
oil pump drive $5
timing chain gear $5
IACV sold
Alternator bracket 20
power steering mount $12
starter sold
MAF sold
upper & lower intake mani $30
HKS 90 degree filter pipe $15
redtop 02 sensor SOLD
radiator $50 (aftermarket jdm)
S13 block w/ crank $150
eagle rods w/ bearings $320
SR20VE head SOLD
CAS sold
E5 ecu x 2 SOLD
62 ecu x 2 SOLD
Megan Down pipe sold
HKS down pipe SOLD
s13 sr20 redtop motorset w/o turbo $1,400
SR EVO 8 turbo setup $620
s13 power doors $150
s13 wingless hatch x2 100 each
s13 popup hood x2 $75 each
S13 gas tank $50
s13 RUCA's pair $20
S14 toe arms $20
S13 front LCA's x2 pairs $30 each
S13 manual doors $60
S13 tension arm brackets $30
S13 front cross member x2 $40 each
S13 rear subframe x2 $50 each
S13 carpet $50
S14 carpet $50
S13 Tein Tension Arms $80
S13 SR koyo Radiator sold
Bee*R rev limiter $200
S14 steering rack $75
S13 hicas steering rack $100
S13 welded diff $75
S13 brake pedal x3 $40 each
S13 clutch pedal x2 $40 each
S13 5spd driveshaft x2 $100 each
Personal (wooden) steering wheel $100
screamer Pipe SOLD
S13 A pillar panel $10
S13 gauge cluster surround x 4 $20 each
S13 shifter trim $10
S13 kick panels $15
S13 glove box $15
S13 center console x 2 $30 each
S13 steering wheel shrouds x 4 $20 each
S13 hvac $40
electronic items have been tested and are in working shape
sold as is
no refunds sorry
Willing to ship
add 3% for Paypal
914 382 2116
[email protected]
First come first serve. $ talks.
Sent from my SPH-L710 using Tapatalk 2
www.NYZC.net
Supergoji is offline   Reply With Quote
