Old 10-30-2012, 12:37 AM   #1
canz33
canz33's Avatar
canz33 is an unknown quantity at this point
S15 sr20det in S14 speed signal
Im using a s15 sr 6speed in s14 setup and I got the cluster working by using dakota digital sgi-5 but when i hook up consult and use data scan the ecu reads the speed 10-15 mph off. I was just worried, would it cause any problems in case of abs functionality since the speed signal is used along with abs signal or something similar.
canz33 is offline   Reply With Quote
Old 10-30-2012, 04:17 PM   #2
Kingtal0n
Kingtal0n's Avatar
the dakota box just fixes what the cluster reads. I have played with it before, and it was always off a little bit, you can play with tire size to get it really really close.
Also, you can use the S14 speed sensor in the S15 transmission. But if you have the S15 differential, you still need the dakota box.
tinyurl.com/4l80er
Old 10-31-2012, 02:14 AM   #3
canz33
canz33's Avatar
Thats not what i meant. I know what it does. My question is it important what ecu reads in terms of speed. Would it cause abs to work improperly or anything like that?
