Old 11-01-2012, 05:29 PM   #1
Guilty1s
Guilty1s is an unknown quantity at this point
Offset difference in Z33 track rotors and R33 GTR rotors
The 350z/g35 Brembo track rotors and the R33 GTR brembo rotors are the exact same dimensions as each other (324mm diameter x 30mm width x 5x114.5 bolt pattern) except that the Z33 rotor is less offset by 4-5mm from the hub then the R33 rotor is.
I need to know that difference in offset if anybody has any info on that. I thought that DBA used to have a database on that.
Worst comes to worse, I have a set of Z33 rotors if anyone could precisely measure on a R33 rotor from the back facing of the rotor to the inside facing where it mounts to the hub.
I appreciate any help.
Guilty1s is offline   Reply With Quote
