![]() Join Date: Feb 2007
Trader Rating: (65)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 65 reviews
JZgte SALE 3 2jz's & 2 1jz's
i have a few motors sitting at the shop & would like to turn them into $$
can also work out some trades or what ever..Also can install or wire them for your chassis u choose to drop them in.. ![]() fell free to give me a call/text or PM anytime 1(714) 330-0021 Spencer @ SideWays Performance update::here are some of the swap that we just finshed http://zilvia.net/f/media-forum-pict...n-working.html 1. this is a Aristo first gen 2jzgte twin turbo swap with 49km on it has ecu & harness..$2400 The 2JZ-GTE is an inline-layout, six-cylinder, belt-driven dual-overhead camshaft, air-intercooled, twin-turbocharged, cast-iron block, aluminium cylinder headed engine designed and manufactured by Toyota Motor Corporation that was produced from 1991 until 2002 in Japan. Development and evolution of the engine was, principally, a response to Nissan's relatively new and then-successful RB26DETT engine which had achieved palpable success in FIA Group A and Group N touring car championships, For all road car applications, two gearboxes were available for the engine: Toyota A341E 4-speed automatic Toyota V160 and V161 6-speed manual (jointly developed with Getrag as the Type 233) The 2JZ-GTE originally powered the Toyota Aristo V (JZS147) in 1991 before becoming Toyota's flagship performance engine in the Toyota Supra RZ (JZA80). Its mechanical basis was the existing 2JZ-GE, but differed in its use of sequential twin turbochargers and an air-to-air side-mounted intercooler. The engine block, crankshaft, and connecting rods of the Supra's 2JZ-GE and 2JZ-GTE are the same, with notable differences being that the 2JZ-GTE has recessed piston tops (giving a lower compression ratio) and oil spray nozzles to aid in cooling the pistons. However, other 2JZ-GE equipped models (Aristo, Altezza, Mark II) share a different part number for connecting rods. Toyota's VVT-i variable valve timing technology was added to the engine beginning in September 1997, whence it phased out the original engine. Consequently, maximum torque and horsepower was raised for engines selling in all markets. The addition of twin turbochargers, jointly developed by Toyota with Hitachi, in sequential configuration had raised its commercially cited output from 230 PS (169 kW; 227 hp) to the contemporary industry maximum of 280 PS (206 kW; 276 hp) at 5600 rpm. In its first appearance, torque was advertised as 44.3 kgm (435 Nm, 320 lbft) at 4000 rpm to be later recited as 46.0 kgm (451 Nm, 333 lbft) with the introduction VVT-i in production year 1997. The mutually agreed, industry-wide output ceiling was enforced by Japan's now-defunct Gentlemen's Agreement exclusively between Japanese automakers selling to the Japanese domestic market. Engine power in the North American and European markets, as documented by Toyota, was increased to 325 PS (239 kW; 321 hp) at 5600 rpm. The export version of the 2JZ-GTE achieved its higher power output with the use of newer stainless steel turbochargers (ceramic for Japanese models), revised camshafts, and larger injectors (550 cc/min for export, 440 cc/min for Japanese). The mechanical similarities between the Japanese-specification CT20 turbine and export-specification CT12B turbine allow interchangeability of the exhaust-side propeller shaft. Additionally, the export-exclusive CT12B turbine received more durable turbine housings and stainless steel turbine and impeller fins. Multiple variants of the Japanese CT20 turbine exist discretely, which are identified with the B, R, and A part number suffixes (e.g.: CT20A). ![]() ![]() ![]() ![]() 2.2jzge both outta a sc300 no harness but do have ecu's 1. is a 96 with 156k on it $550 2. is a 95 with 180k $500 both pulled out running cars for twin turbos The 2JZ-GE is a common version. Output is 220 hp JIS (158 to 169 kW) at 5800 to 6000 rpm and 209 to 220 lb·ft (283 to 298 Nm) of torque at 3800 to 4800 rpm. It uses Sequential Electronic Fuel Injection, has an aluminum head and 4 valves per cylinder with some versions using VVT-i, along with a cast-iron cylinder block. The VVT-i version also featured DIS in favor of the traditional distributor set-up previously seen on the 2JZ-GE. Despite common misconception it was not a true COP (Coil-On Plug) ignition system instead relying on one coil to fire two cylinders, one of which was by spark plug wire ![]() ![]() 3.1jzgte Soarer/sc300 twin turbo motor nice and clean & ready to be swapped in.has harness & ecu. 66km on this on $1400 The 1JZ-GTE employs twin CT12A turbochargers arranged in parallel and blowing through a side-mount or front mount air-to-air intercooler . With an 8.5:1 static compression ratio, the factory quoted power and torque outputs are 280 metric horsepower (210 kW) at 6200 rpm and 363 newton metres (268 lbf·ft) at 4800 rpm respectively. The bore and stroke are the same as for the 1JZ-GE: 86 mm (3.39 in) bore × 71.5 mm (2.81 in) stroke. Yamaha may have had a hand in the development or production of these motors (possibly the head design), hence the Yamaha badging on certain parts of the motor, such as the cam gear cover. In 1991, the 1JZ-GT7E was slotted into the all-new Soarer GT. The early generation 1JZ-GTEs combined the inherent smoothness of an inline 6-cylinder engine with the revving capacity of its short stroke and early power delivery of its small, ceramic wheeled turbochargers. The ceramic turbine wheels are prone to delamination in the setting of high impeller rpm and local temperature conditions, usually a result of higher boost. The first generation 1JZs were even more prone to turbo failure due to there being a faulty one-way valve on the head, specifically on the intake cam cover causing blow-by gases to go into the intake manifold. On the exhaust side, a decent amount of oil vapor flows into the turbos causing premature wear on the seals. The later second generation engines had this problem fixed and in Japan there was actually a recall in order to repair the first generation engines, though that does not apply to 1JZs imported to other countries. The fix is simple, and involves replacement of the PCV valve (2JZ); all parts are available through Toyota. The third generation of the 1JZ-GTE was introduced around 1996, still as a 2.5-litre turbo, but with Toyota's BEAMS architecture.[2] This included a reworked head, newly developed continuously variable valve timing mechanism (VVT-i), modified water jackets for improved cylinder cooling and newly developed shims with a titanium nitride coating for reduced cam friction.[3] The turbo setup changed from parallel twin turbo (CT12x2) to a single turbo (CT 15B). The adoption of VVT-i and the improved cylinder cooling allowed the compression ratio to be increased from 8.5:1 to 9.0:1. Even though the official power figures remained at 280 metric horsepower (210 kW) at 6200 rpm, torque was increased by 20Nm to 379 newton metres (280 lbf·ft) at 2400 rpm. These improvements resulted in increased engine efficiency that reduced fuel consumption by 10%. The adoption of a much higher efficiency single turbocharger than the twins as well as different manifold and exhaust ports were responsible for most of the 50% torque increase at low engine speeds . This engine was used primarily in Toyota's X chassis cars (Chaser, Mark II, Cresta, Verossa), the Crown Athlete V (JZS170) and in the later JZZ30 Soarer, as the JZA70 Supra was long discontinued by this time. ![]() ![]() 4. also got 2 1jzgte jdm auto trans. one is supper clean inside & out. other looks normal for its age $200 each ![]() ![]() 5.blown 1jzgte has low compression in 2 & 5. no turbos or injectors on it.. ill post up pix in the next few days $600 Last edited by Spencer dougherty; 01-15-2013 at 10:57 PM.. |
#17 |
LMAO really? You could fit any motor into a s chassis. Wouldnt recomend buying this asking a question like that.
#18 |
![]() Join Date: Dec 2008
Trader Rating: (79)
![]() Feedback Score: 79 reviews
Any R154's in stock? A buddy of mine is in need of one!
My Build: The "Coupe De Ville" 1JZ Build!! |
