Old 11-17-2012, 08:16 PM   #1
hoytt123
hoytt123 is an unknown quantity at this point
Helppppppppp
okay so i was driving my s13 today, and i was playing with the boost a little just doing small pulls, i have all stock s14 sr20det parts, it was good early in the day but then i went back out and had to drive to my friends and i got on the freeway and tried to accelerate, and my boost wouldnt push over 5 pounds when earlier i had 10 pounds, i checked for a boost leak and i could find one, but my car wont go over like 3500 rpms until it feels like it is bogging down. PLEASE HELP!!!!!!!!
hoytt123 is offline   Reply With Quote
Old 11-17-2012, 08:17 PM   #2
Frank_Jaeger
Frank_Jaeger is an unknown quantity at this point
Check MAF
msglngthfkdarules
Frank_Jaeger is offline   Reply With Quote
Old 11-17-2012, 08:19 PM   #3
hoytt123
okay could it just be my airfilter being cloughed i have some janky mushroom like sponge filter that came with the car on it now
Old 11-17-2012, 08:32 PM   #4
K3MPS
K3MPS is an unknown quantity at this point
what fuel pump are you running?
K3MPS is offline   Reply With Quote
Old 11-17-2012, 08:34 PM   #5
hoytt123
walbro 255 i believe, this has never happened before and i do mini pulls like everyday
Old 11-17-2012, 08:37 PM   #6
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
most likely bad maf.
Old 11-17-2012, 08:38 PM   #7
hoytt123
how would i be able to tell?
Old 11-17-2012, 08:38 PM   #8
rb25_s13*CHUKI
rb25_s13*CHUKI's Avatar
maf maf maf maf maf
Obliterate
rb25_s13*CHUKI is offline   Reply With Quote
Old 11-18-2012, 03:40 PM   #9
steve shadows
steve shadows's Avatar
Could be boost leak as well...that is getting worse and worse and worse. I would also check ground for coil packs as well. I would also check your timing since about 90% of the cars I run into the CAS timing or base timing is incorrectly which mean the car runs at like half horsepower....kind of sad...
Like Me on FaceBook !
Old 11-19-2012, 06:47 PM   #10
Cedarcbr
Cedarcbr is an unknown quantity at this point
had pretty much this same issue today and it turned out the 2 of my plugs had hairline cracks in them after 3K miles, not sure how it happened but changed plugs and she runs like a champ now, just my 2 cents
Cedarcbr is offline   Reply With Quote
Old 11-19-2012, 07:49 PM   #11
ultimateirving
ultimateirving's Avatar
Does it only break up at 3500 while in boost? or does itbreak up even if just at cruising speed, say 80mph?
Because if it breaks up in boost, but not while cruising, you have a boost leak, and need a tester to find it.
If ur maf is bad, i doubt youd even be able to get down the street.
Z32 with lq4 swap
