Old 11-21-2012, 11:14 AM   #1
S14-Jo!
S14-Jo!'s Avatar
S14-Jo! is an unknown quantity at this point
MAP-ECU2 w/S14 SR wiring harness
I recently purchased a Nistune, so I won't be needing this MAP ECU anymore. Its called a plug and play harness but it will require a little bit of wiring, but its not complicated.
Here is just the basics of what it can do:
The MAP-ECU2 (Manifold Absolute Pressure Electronic Control Unit) is a full featured fuel and timing controller with the following additional features:
Full Timing advance and retard control of up to eight (8) channels for Distributor, Group Fire or Coil On Plug configurations using a 20 x 19 (380 zone) table.
Auxiliary Injector control using a 20 x 19 (380 zone) table.
OEM O2 Sensor/AFR Sensor Adjust 26 x 19 (494 zone) table allowing control over Air/Fuel ratios, even in Closed-loop mode.
Expanded RPM scale now up to 10,000 RPM.
Two (2) complete sets of Fuel, Timing, Auxiliary Injector, O2 Adjust and EBC tables selectable using a dashboard mounted switch.
Electronic Boost Control with 1000 RPM target boost points.
Launch Control
Dual channel Fuel Cut Defeat
Speed Cut Defeat
Built-in 35PSI MAP Sensor
External MAP Sensor option
User selectable pressure scale configurations Ă‚
Link: Underdog Racing Development
I need money for the holidays, so Im looking for a quick sale. $350 shipped!
Pm and I will get back to you as soon as possible.
Thanks
S14-Jo! is offline   Reply With Quote
Old 11-26-2012, 10:41 AM   #2
S14-Jo!
S14-Jo!'s Avatar
Bump $330 shipped for cyber monday!
Old 12-04-2012, 02:02 AM   #3
S14-Jo!
S14-Jo!'s Avatar
Bump, I will also entertain trade offers, parts for S14/kouki/SR20/gauges/etc.
Old 12-07-2012, 01:13 AM   #4
S14-Jo!
S14-Jo!'s Avatar
$310 SHIPPED
Tuition and books are coming up
Old 01-27-2013, 09:48 AM   #5
S14-Jo!
S14-Jo!'s Avatar
sold!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
