Old 03-22-2004, 12:11 PM   #1
formeRiceR
formeRiceR is an unknown quantity at this point
still running rich...
So I'm still running rich and I still don't know why?
My idle is still around 850-900 RPM
Here are some guesses:
1, My voltage for my TPS is at 1.45 kohms at closed throttle is that normal for a S!4 built in 7/94. I heard it was 2 kohms then I heard it was 1 kohms. So I'm somewhat confused about that.
2, So friday I was underneath the car and a turns out that my car does have 2 O2 sensors, well I think it is a O2 sensor. it's before the dummy cat and is on that long pipe. Is that a O2 sensor ??? I should probably swap that out right?
3, Coolant sensor, so when I first had the car when the car was all warmed up the temp gauge would be in the middle. Now a days even if I drive hard the needle stays on the lower end of the gauge. I'm wondering if this is the coolent sender being screwed or if it's my thermostat or something? Can a thermosat be stuck open??? I know they can be stuck closed...
4, Could it also be my timing...??
Also, MAFS reads good and no ECU codes are popping...
"Street racers don't need girls." -Lonely Driver
Learning about cars one FLAME at a time ... (thanks to TNORD)
formeRiceR is offline   Reply With Quote
Old 03-22-2004, 02:59 PM   #2
Yoshi
Yoshi's Avatar
Yoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to behold
1, My voltage for my TPS is at 1.45 volts at closed throttle is that normal for a S!4 built in 7/94. I heard it was 2 volts then I heard it was 1 volt. So I'm somewhat confused about that.
um... KA? SR? KAT?
www.360realms.com/S13-S15
Yoshi is offline   Reply With Quote
Old 03-22-2004, 03:44 PM   #3
formeRiceR
ka w/ intake and exhaust
Old 03-22-2004, 10:01 PM   #4
Yoshi
Yoshi's Avatar
has your car always idled that high?
does it surge?
o2 sensor would be my first guess
