Old 03-22-2004, 06:50 PM   #1
citizen
citizen's Avatar
citizen is making a name for him/her selfcitizen is making a name for him/her selfcitizen is making a name for him/her self
Send a message via AIM to citizen
Play in vlsd
While having my car up on the lift i was inspection for some noise coming from the rear end when i was starting the car from a stand still, a sort of clunking. I found what would seem to be excessive play in the diferential. The drive shaft input into the carrier can rotate maybe 5-10 degrees before it engages. Im sure that this is causing the noise. What do i need to tighten or what could have worn?
citizen is offline   Reply With Quote
Old 03-22-2004, 11:58 PM   #2
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
your LSD is fu*ked man. SUcks to be you. JK. You need to come drive with me. Hit me up.
Matt
DJPimpFlex is offline   Reply With Quote
Old 03-23-2004, 02:09 AM   #3
citizen
citizen's Avatar
dousche bag, after i fix my car.
Old 03-23-2004, 06:02 PM   #4
citizen
citizen's Avatar
Im sure this has happened to another person?
Old 03-23-2004, 06:10 PM   #5
Var
Var's Avatar
Var is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of light
Send a message via AIM to Var
why do you assume the free play is in the diff? this usually doesnt happen. more than likely it's in the driveshaft itself.
Hi
Var is offline   Reply With Quote
Old 03-23-2004, 06:56 PM   #6
citizen
citizen's Avatar
because i rotated the companion flange and the play was in the diff......
Old 03-23-2004, 11:30 PM   #7
Var
Var's Avatar
ahh. well in this case you are probably gonna spend more for repairs than it would cost to get a new diff. Good luck.
Hi
