Old 12-12-2012, 03:50 PM   #1
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Largus sway bars for sale
Up for sale is a used pair of Largus sway bars.
The front is tweaked on one side. It still bolts up fine, its just about 1" off where it meets the end link that goes to the LCA. I ran this on my SR WITH a/c and you will have to shave down part of the a/c compressor for it to clear. Most people don't run a/c so its a non issue. Also i have a greddy oil pan and it clears.
Rear bar is in perfect condition, but the paint isn't perfect. Not that thats an issue. See pics for details.
Rear bar also fits s14 subframe. I was running an s14 rear subframe in my s13 and it bolted up fine with no modification.
FRsport sells them new for $575
FR Largus Front and Rear Sway Bars S13 Chassis
these things are hella jdmtight, and will be like vteks on bathsalts. also, your balls will swell up like melons and all your friends will call you peter north. or maybe just your car will handle better.
Stock s13 Front is 27.2 Rear is 16mm
Largus Front is 31.5 Rear is 27.5
These shits are pretty much the beefiest bars on the market for s-chassis. If there are any larger ones i'm not aware of em.
Kazama, Nomuken, Kunny'z, and Tezuka all use these. You probably should too if you wanna
LARGUS SWAY BAR KIT F & R SET: 89-94 NISSAN 240SX Hatchback
SOLD!!!!
Mods plz close.
562 519 5577
Tyler
\/\/\/\/ you can see on the right side how the end is tweaked in slightly
Old 12-13-2012, 02:24 AM   #2
illvialuver
illvialuver's Avatar
Super legit, MC HAMMER would approve.
Old 12-13-2012, 03:18 AM   #3
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
Luvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of light
Feedback Score: 81 reviews
What bushings did you use with these?
Luvs2slide is offline   Reply With Quote
Old 12-13-2012, 06:00 AM   #4
brndck
brndck's Avatar
You can either order energy suspension, whiteline, or use a worn pair of stock bushings.
