Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Forced Induction
Old 12-12-2012, 10:07 PM   #1
468POWER
468POWER is an unknown quantity at this point
Exclamation DOC RACE TURBO MANIFOLDS Blowout Holiday Sale & FREE Shipping!!!
WE HAVE DEFINATELY BEGAN DRINKING EARLY WITH TOO MUCH EGG NOGG AND BUBBLY AS OUR HOLIDAY SALE WITH FREE SHIPPING IS LEAVING US WITH NO PROFITS ON THESE QUALITY GOOD 'OL USA MADE DOC RACE TURBO MANIFOLDS AND INTERCOOLERS!!! CONSIDER IT A PRESENT TO ALL OUR FELLOW ZILVIA NISSAN FANS FROM THE BESTEST DOC RACE AUTHORIZED DEALER - PERFORMANCE AUTOWORKS!!!
POST YOUR INQUIRIES HERE, PM, OR EMAIL US FOR OUR BLOWOUT HOLIDAY PRICES.
MAKE IT A VERY MERRY CHRISTMAS, HAPPY HANUKKAH, KWANZAA, AND/OR FESTIVUS FOR THE REST OF US BY PURCHASING ONE OF THESE BAD BOYS FOR A LOVED ONE OR IF YOU LOVE YOURSELF!!!
HERE ARE THE DETAILS AND PICS OF EACH MANIFOLD. WE ALSO HAVE MANIFOLDS FOR 350Z TURBO, Toyota 2JZ, 1JZ, Mazda 93+ RX7, Mazda Miata, Honda and more! We carry every item DOC Race manufactures. See their website for further details...
DOC Race Store, Turbocharging Components
For SR20DET...
Nissan SR20DET T3 Top Mount Manifold
Application notes:
-T3 flange
-Option for 2-bolt 38mm, Tial MVS or MVR/44mm wastegate flange
-Retains AC
Stainless downpipes are also available upon request for $350 in 3" Stainless with 4-bolt, 5-bolt or V-band flange.
The DOC Race Topmount Turbo manifold is for the more extreme setup looking for the potential limit of the vehicles engine. The DOC Topmount manifold can still be used for “streetable” vehicles, but is solely designed to make maximum horsepower and allow you to fit much larger frame turbo’s then our traditional ramhorn. D.O.C. still applies our elaborate porting process to complement maximum flow within ALL of our manifolds.
Nissan SR20DET T25 Bottom Mount
The DOC Race SR20DET T25 Bottom mount turbo manifold places your t25/28 framed turbocharger in the factory location. Made from sch 40 stainless steel and a true merge collector this manifold will maximize the output of any turbo that will fit on it.
Nissan SR20DET T4 Front Facing Manifold
Application notes:
-Open T4 flange (T3 option available below)
-Single Tial MVR or Dual MVS gate option
-Retains Powersteering and Air Conditioning on S Chassis
The DOC Race T4 Topmount Turbo manifold is for the more extreme setup looking for the potential limit of the vehicles engine. This manifold is capable of well over 1000hp in our Twinscroll version and is designed for peak-power situations. The DOC Topmount manifold can still be used for “streetable” vehicles, but is solely designed to make maximum horsepower and allow you to fit much larger frame turbo’s then our traditional T3 Center set manifold. D.O.C. still applies our elaborate porting process to complement maximum flow within ALL of our manifolds.
Nissan SR20DET V-Band Top Mount Manifold
Application notes:
Tial V-band Inlet flange
Option for MVS or MVR V-band wastegate flange
Retains AC
The DOC Race Topmount Turbo manifold is for the more extreme setup looking for the potential limit of the vehicles engine. The DOC Topmount manifold can still be used for “streetable” vehicles, but is solely designed to make maximum horsepower and allow you to fit much larger frame turbo’s then our traditional T25 Bottom-mount. D.O.C. still applies our elaborate porting process to complement maximum flow within ALL of our manifolds.
SR20DET High Port Billet Intake Manifold
DOC Race Billet SR20DET Intake Manifold. Works with most throttle bodies including the Ross Machine 90mm.
DOC Race Intake Manifolds are designed for extreme boost applications with increased plenum size and calculated runner length for optimum power delivery. These intake manifolds have CNC intake ports for proper airflow through the plenum. Intake manifolds are standard with a billet flange and an array of throttle body possibilities such as the sought after 90mm in the Mustang bolt pattern. DOC still applies our elaborate porting process to complement maximum flow within ALL of our manifolds.
This Intake Manifold is designed for maximum output of your SR20DET engine. ECU tuning will be necessary to gain all the possible torque that comes with this High Volume Intake Manifold.
-Will also work with factory-medium sized cams and smaller frame turbo's for mid-range gains.
For KA24DE Turbo...
KA24DE T3 Topmount Manifold
DOC Race Nissan KA24DE Topmount Manifold
-Fits ALL Twincam KA24DE Engines, 91-98 240SX
-Powersteering pump bracket modifications necessary
Available with a MVS or MVR wastegate flange, this T3 turbo manifold is for the more extreme setup looking for the potential limit of the vehicles engine. The DOC KA Topmount turbo manifold can still be used for “streetable” vehicles, but is solely designed to make maximum horsepower and allow you to fit much larger frame turbo’s then our traditional bottom-mount T25 manifold. D.O.C. still applies our elaborate porting process to complement maximum flow within ALL of our manifolds.
KA24DE T25 Bottom-Mount
The DOC Race Nissan KA24DE T25 Bottom-mount Turbo Manifold was designed to be a bolt-on manifold that will support most Internally Gated T2 frame turbo's. This manifold is able to use the SR20DET T25 Turbo outlet and retains A/C and Powersteering.
Made with 304 sch 40 Stainless steel and a true merge collector, this hand-built piece will take your T28 frame to the maximum!
For RB20/25/26...
RB20/25/26 Openscroll Topmount
DOC Race Open T4 Topmount available for RB20/25/26
-T4 Open Inlet Flange
-Single MVR Wastegate flange standard
The DOC Race RB Topmount Turbo manifold is for the more extreme setup looking for the potential limit of the vehicles engine. The DOC Topmount manifold can still be used for “streetable” vehicles, but is solely designed to make maximum horsepower and allow you to fit Larger Frame Turbo's. D.O.C. still applies our elaborate porting process to complement maximum flow within ALL of our manifolds.
RB20/25/26 Twinscroll Topmount
Application Notes:
-Standard with Dual Tial MVS V-band wastegate outlets
-Up to 4" downpipe
Tubing specs: 1.660" OD, 1.380" ID, 0.140" wall rated for 1300hp
The DOC Race Twinscroll Turbo manifold is similar to our Topmount manifold application. Our Twinscroll manifold is for maximum flow of your engine and turbo including the best possible spool and no limitations of the maximum output of your combination. DOC Race Twinscroll manifolds have had years of development in order to utilize the proper exhaust pulses to eliminate unwanted exhaust backpressure and vale overlap, in-turn giving you maximum airflow. This manifold is simply the most efficient available on the market! D.O.C. still applies our elaborate porting process to complement maximum flow within ALL of our manifolds.
Again Happy Holidays and HAPPY NEW YEAR to all fellow Zilvia members and their families from Performance Autoworks!!!
468POWER is offline
Old 12-12-2012, 10:25 PM   #2
Mitsubayati
Trader Rating: (18)
Mitsubayati is an unknown quantity at this point
Feedback Score: 18 reviews
Send a message via AIM to Mitsubayati
How much for the RB25 Top mount open scroll manifold?
http://www.fittedlife.com/images/nickbanner.jpg
Mitsubayati is offline
Old 12-12-2012, 10:35 PM   #3
801nismo104
801nismo104 is an unknown quantity at this point
price on sr20det t3 top mount and sr20det vband topmount please
801nismo104 is offline
Old 12-13-2012, 01:43 AM   #4
K_style
K_style's Avatar
Trader Rating: (63)
Feedback Score: 63 reviews
Price for T3 top mount with 44mm and T2 bottom mount for SR20DET
K_style is offline
Old 12-13-2012, 02:10 AM   #5
91EfSi
91EfSi is an unknown quantity at this point
Price for Rb20/25 Openscroll top mount as well.
91EfSi is offline
Old 12-13-2012, 03:33 AM   #6
irritatedmax
irritatedmax's Avatar
irritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enough
SR T25 bottom mount price, please.
BRICKHOUSE PRODUCTS
IG @brickhouse_products
irritatedmax is offline
Old 12-13-2012, 07:23 AM   #7
1quk240
Banned from the Marketplace
1quk240 will become famous soon enough1quk240 will become famous soon enough1quk240 will become famous soon enough1quk240 will become famous soon enough
PM price for NA 2jz-ge t3 twinscroll shipped to 85301 please.
1quk240 is offline
Old 12-13-2012, 08:49 AM   #8
mechavore884
mechavore884's Avatar
mechavore884 is not welcome here anymoremechavore884 is not welcome here anymoremechavore884 is not welcome here anymoremechavore884 is not welcome here anymoremechavore884 is not welcome here anymoremechavore884 is not welcome here anymoremechavore884 is not welcome here anymoremechavore884 is not welcome here anymore
price for KA24de T3 shipped to 23507
mechavore884 is offline
Old 12-13-2012, 09:50 AM   #9
468POWER
Whoooweee - all PMs and posts replied to! Santa and his raindeer are gonna be a busy man these next two weeks if you guys all jump on this limited deal!
468POWER is offline
Old 12-13-2012, 10:11 AM   #10
str84dapokie
str84dapokie's Avatar
str84dapokie is an unknown quantity at this point
KA24DE T25 Bottom-mount Turbo Manifold shipped to 08835
www.iDigsThat.com
....Check it out....
str84dapokie is offline
Old 12-13-2012, 11:01 AM   #11
MrJdmEh2
MrJdmEh2's Avatar
MrJdmEh2 is an unknown quantity at this point
can i get a price for a sr20 t25 bottom mount to 11206 thanks.
MrJdmEh2 is offline
Old 12-13-2012, 03:31 PM   #12
ForeignMuscle
ForeignMuscle is an unknown quantity at this point
3" sr20det downpipe..
Is it just one piece or the two piece like Mazworx that replaces the bottom downpipe before the cat?
Noone selling these has been able to give me any info on the downpipe. Paypal ready I need one TODAY.
Thanks!
ForeignMuscle is offline
Old 12-13-2012, 07:00 PM   #13
Theworm
Theworm is an unknown quantity at this point
Price for - KA24DE T3 Topmount Manifold shipped to 52001
Thanks
Theworm is offline
Old 12-13-2012, 09:20 PM   #14
VATOCLOWN
VATOCLOWN is an unknown quantity at this point
price for front face manifold sr20det in t3 config if possible
VATOCLOWN is offline
Old 12-13-2012, 09:29 PM   #15
AVmagneticZ
AVmagneticZ is an unknown quantity at this point
interested in the price of the t3 top mount and t28 oem location bottom mount manifold for sr20
AVmagneticZ is offline
Old 12-14-2012, 06:08 AM   #16
468POWER
All PMs and posts replied to! Keep em coming.
468POWER is offline
Old 12-14-2012, 06:52 AM   #17
ForeignMuscle
Except mine...
Same exact thing I went through with a previous dealer. Ignored and eventually told "oh, doc didn't give any info on the downpipe.."
Thanks anyway..
Old 12-15-2012, 12:22 AM   #18
468POWER
Originally Posted by ForeignMuscle View Post
Except mine...
Thanks anyway..
Dude, I am waiting for the exact answer to come in from my buddies at DOC RACE. I just emailed them early this morning. It's only been a day since you asked us the question. Patience is a virtue. LMK if you still need an answer.
Regards,
Will
468POWER is offline
Old 12-15-2012, 12:24 AM   #19
LOVERboy
LOVERboy is an unknown quantity at this point
Send a message via AIM to LOVERboy
Ka24de t3 top mount manifold shipped to 91730 please! PayPal ready!!!
Sunny D.-
LOVERboy is offline
Old 12-15-2012, 10:00 PM   #20
ForeignMuscle
Hey bud, no problem. Letting me know that to begin with would have been fine too. Take your time.
Old 12-15-2012, 11:57 PM   #21
468POWER
Weekend now so hope to have an answer for you Monday.
468POWER is offline
Old 12-16-2012, 01:45 AM   #22
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
Luvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of light
Feedback Score: 81 reviews
Price for rb25 top mount twin scroll mani shipped to 96319 and 94535
Luvs2slide is offline
Old 12-20-2012, 11:46 AM   #23
want2drag
want2drag is an unknown quantity at this point
Price on open scroll for rb25, and will it fill s14 with rb25 swap ?
want2drag is offline
Old 12-25-2012, 09:56 AM   #24
468POWER
Merry Christmas fellow Zilvia members!
Some of you must be very happy children when Santa delivered your shiny Doc Race manifolds! Not to worry for those that missed out - the UPS man can deliver the same shiny manifold to your door now if you PM or post on thread for our super low beat all blow out price!
468POWER is offline
Old 12-30-2012, 06:56 PM   #25
Gripstarr
Gripstarr is an unknown quantity at this point
how much for the sr20det t4 front setting manifold shipped to 70452??
Gripstarr is offline
Old 01-10-2013, 10:04 AM   #26
468POWER
You have PM.
468POWER is offline
Old 01-14-2013, 04:25 PM   #27
Riodcs
Riodcs is an unknown quantity at this point
ka top manifold shipped to 60056
can u guys make ka intake manifold?
Riodcs is offline
Old 01-15-2013, 07:45 PM   #28
468POWER
You have PM.
468POWER is offline
Old 02-09-2013, 03:10 AM   #29
1gr8bar10der
1gr8bar10der's Avatar
Trader Rating: (77)
Feedback Score: 77 reviews
SR T25 bottom mount shipped to 33615 please.
1gr8bar10der is offline
Old 02-09-2013, 08:52 AM   #30
ng26
ng26 is an unknown quantity at this point
Ka top mount shipped to 80817?
ng26 is offline
