Old 12-15-2012, 10:35 AM   #1
supertrogdor
supertrogdor is an unknown quantity at this point
Rb no spark
Ok so I've searched and searched and I can't find any info that matches what I have. Here is my problem I have a s1 rb25 and a wiring specialties rb to s14 harness I have hooked everything up and instill have no spark. I have a feeling it's the ignitor but everything that I see online says that the ignitor is 6 wires on the harness side and 7 on the coil pack side and mine is different. I have 7 on the harness side and 6 on the coil side. There is also an extra plug on the coil harness that has 2 wires. Pic is attached
supertrogdor is offline   Reply With Quote
Old 12-15-2012, 01:07 PM   #2
davidg01234
davidg01234 is an unknown quantity at this point
How are u checking for spark?
davidg01234 is offline   Reply With Quote
Old 12-15-2012, 01:20 PM   #3
supertrogdor
Grounding the plug against the block
Old 12-15-2012, 01:26 PM   #4
davidg01234
Open up the ecu and look REALLY good for burn marks or broken pieces. Also smell for a burnt sensation as well. Make sure u check both sides of the ecu.
Old 12-15-2012, 01:39 PM   #5
supertrogdor
Ok I will check that
Old 12-15-2012, 10:56 PM   #6
supertrogdor
Pulled ecu checked both sides nothing looks burned or smells funny. I also tried another ecu and still nothing.
Old 12-15-2012, 11:10 PM   #7
OutToWinPAHC
OutToWinPAHC's Avatar
OutToWinPAHC is an unknown quantity at this point
Send a message via AIM to OutToWinPAHC
have you checked the coil packs for power?
OutToWinPAHC is offline   Reply With Quote
Old 12-16-2012, 07:37 AM   #8
davidg01234
Hmm for some reason it seems like your not getting any power to the coils. If I were u, I would take a multimeter and check each plug on the coilpack harness to see if your getting power to them. That way if you do have power going through them, then u know its the coilpacks themselves.
Old 12-16-2012, 07:41 AM   #9
davidg01234
Also do u think theres a chance you have a wrong ignitor? Sense u said it has 6 on the coil side and 7 wires on the harness side? I have a s2 rb25 so I dont know much about those ignitors
Old 12-16-2012, 07:50 AM   #10
supertrogdor
I could have the wrong igniter I bought it on eBay so it very well could be the wrong one. I'm at the point where I'm willing to do the grand national coil setup.
Old 12-16-2012, 08:25 AM   #11
Jtuned_andy
Jtuned_andy's Avatar
Trader Rating: (28)
Jtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud of
Feedback Score: 28 reviews
http://home.comcast.net/~skunk.werkz/r32_sig.jpg
Jtuned_andy is offline   Reply With Quote
Old 12-16-2012, 09:31 AM   #12
davidg01234
Well thats always an option too but it could just be a bad or wrong ignitor
Old 12-17-2012, 04:24 PM   #13
greenwood
greenwood's Avatar
greenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymore
how is your CAS
greenwood is offline   Reply With Quote
Old 12-17-2012, 06:47 PM   #14
supertrogdor
Cas is good I get injector pulses when I turn it
Old 12-18-2012, 09:27 AM   #15
baube
baube is an unknown quantity at this point
power to coils? white thick wire (middle one in each coil plug) should have constant batt voltage when key in "on"
eccs relay and ign relay turn on? (both green beside ecu)
don't forget to ground the small black wire comming off the coilpack loom on the valve cover near the ignitor
baube is offline   Reply With Quote
Old 12-31-2012, 03:04 PM   #16
supertrogdor
Back form the dead. Ok I have power going to the white middle wire. I only have 1 relay next to the ecu and it is good. All 6 coils check out ok. So I'm thinking its the ignitor is there any way to check at the coil plugs to see if the ignitor is working?
Old 12-31-2012, 03:07 PM   #17
OutToWinPAHC
yea, do you have an oscilloscope?
Old 12-31-2012, 03:27 PM   #18
supertrogdor
That I do not
Old 12-31-2012, 04:01 PM   #19
OutToWinPAHC
then no not even with a good meter like my Fluke 187, you need a scope.
