Old 03-27-2004, 06:12 PM   #1
Mr. Spool
Mr. Spool is an unknown quantity at this point
spark plugs
I am running 4 psi on my kat and am wondering what plugs I should go with and what gap they should be.
96' SE Turbo'd
Super 60, S-AFC, SMIC, 370cc Injectors,
Open Air BOV, Warblo 255 pump, Stage 3 Clutch
Kyb agx, Sportline Springs
Full body kit, Bomex rear, Drift sides, r34 front
gunmetal rims, yok tires
Mr. Spool is offline   Reply With Quote
Old 03-27-2004, 06:13 PM   #2
nightwalker
nightwalker's Avatar
nightwalker is an unknown quantity at this point
good ones.
In life, we often cast the line of hope fishing for the best possible opportunity. Sometimes with enough effort, the things we catch are nothing short of amazing.
nightwalker is offline   Reply With Quote
Old 03-27-2004, 06:52 PM   #3
Mr. Spool
Thanks, LOL, any other imput, should I get hot ones or cold ones. and should the gap be more or less than stock.
96' SE Turbo'd
Old 03-27-2004, 06:56 PM   #4
thelinja
thelinja's Avatar
thelinja is making a name for him/her selfthelinja is making a name for him/her self
Nice response, idiot. Anyway, I'd definetely go with a higher heat range. www.pdm-racing.com sells Iridium NGK plugs with a heat range of 9 I believe? I'd go with those. Oh yeah, higher heat range =colder plug.
thelinja is offline   Reply With Quote
Old 03-27-2004, 07:56 PM   #5
russian
russian's Avatar
russian is an unknown quantity at this point
Send a message via AIM to russian
you dont really need colder plugs at 4psi. benefits would be minimal, but if you wanna spend extra cash, god bless.
I must break you.
russian is offline   Reply With Quote
Old 03-27-2004, 07:59 PM   #6
Mr. Spool
Thanks for the responses, I am hoping to be at 7psi by the end of next month. The reason why I am asking this is becouse on my 300tt I noticed that if I used the right plugs and the proper gapping I could dramatically improve the amount of power my car put out. I was wondering if the same held true for out vehicles with turbos.
96' SE Turbo'd
Old 03-27-2004, 11:33 PM   #7
nightwalker
hahaha! sometimes you feel like a nut, sometimes, you... whatever. Look into some Iridium plugs. You can get Densos one for a good price, somewhere around 40-50 for 4 I believe. They do cost a little more, but last longer, and are better. The cost is offset by not having to change your plugs so often. If you do a research on plugs, you'll see why the Iridium plugs are the way to go. NGK also makes very nice Iridium plugs, in different ranges, but they are more expensive. If you have to absolutely be cheap, buy regular NGK plugs, and stay away from the Bosch plugs. But for such a little price, I wouldn't.
Old 03-28-2004, 12:05 AM   #8
russian
russian's Avatar
wth is wrong with bosch plugs??
I must break you.
Old 03-28-2004, 12:33 AM   #9
Nismo240SX
Nismo240SX's Avatar
Nismo240SX is on a distinguished road
Send a message via AIM to Nismo240SX
Don't waiste money on iridium spark plugs, they foul out pretty easy. we use NGK 7 series plugs at JGY Customs, on almost all of our of cars/installs. We even use the 7 series on our Sentra Se-r Drag car.
1990 Nissan 240sx:s13 blacktop, s13.5 front
Nismo240SX is offline   Reply With Quote
Old 03-28-2004, 01:14 AM   #10
nightwalker
To each his own. The NGK plugs are really nice and well designed. I personally like the Iridium plugs, and have not had them foul on me. My NGKs seem to foul pretty quick actually, so whatever. I usually check my plugs every 10-12k.
Bosch is NOT as bad as I make them to be, but for the same price for Bosch and NGK, NGK is the better buy.
I'm not in the mood to be typing a lot of techy stuff, so someone else can chime in if they feel like it. Denso does a pretty good job of describing a plugs functions (maybe sided on their site though ) just google it and learn. Then decide for yourself.
