Old 12-29-2012, 08:33 PM   #1
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
New Brembo 4-Piston Calipers Front
I acquired these several years ago and kind of forgot about them in the basement after moving etc. They are brand new, however they incurred very slight damage to the finish while in storage. I touched up the areas and they are barely noticeable from a slight distance. As you will see in the pics, I also took closeups of the touched up areas. Brackets will need to be purchased from Brembo for your specific vehicle application. Or if you are talented then maybe you could make your own. I believe these will work with the 332mm rotors but you may want to double check with Brembo.
The part # for the calipers is: 20.8662.00
Asking $500 or best offer
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 12-30-2012, 09:37 AM   #2
Gamma
Gamma is an unknown quantity at this point
Bump for a good deal, GLWS OBO my peeps someone better pick these up
Gamma is offline   Reply With Quote
bbk, brakes, brembo, broadfield, calipers
