Ls1 240!! Help get pig on road!!
240sx ls1 chirp!! Help!? - YouTube
^Video^ don't know how to embed! Sorry. Just got it in and took it or a test drive. On the test drive it overheated due to a bad water pump. Upon replacing the water pump it made this noise heard in video. Did reasearch and thought it was a stuck lifter. Bought new Ls7 lifters along with the tsp 224r cam. Replaced all that along with timing chain and ported oil pump. Got it all back togeather and it still making noise. It goes faster as the RPMs increase. I'm using the sikky swap kit with the 1 7/8th headers that I exhaust wrapped. The cylanders hold pressure an the oil pressure is strong. There's no "stripped glitter" in the oil. I'm thinking its the stage 3 monster clutch that I put in before I dropped it in. noise stays the same when clutch is pressed to the floor. but am unsure and want to see if anything minor can be tryed before anything else. I did everything by the book so I have no idea what it might be!! Any help would be beneficial HElp mE get this pig on the road and to the track!!
Current Ride: 1995 Ls1/t56 |
#9 |
![]() Join Date: Jun 2005
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
no problem man,
Can you hear any noises turning crank by hand? Did you check the bottom end before installing? Maybe the starter gear is stuck out? I don't know a whole lot about ls1's but im trying to think of things I would check. If it has hydro lifters they need to be bleed. |
#10 |
Video makes this seem like a bottom end noise. Does the noise increase/decrease with engine RPM? Kind of sounds like a leaking exhaust manifold as well, something to check out.
Mishimoto Automotive |
#11 |
I would check your valve train for sure. Were they new lifters? Did you soak em in oil for a while prior to install??
1998 240SX SE- Low, slow and ready to roll ![]() |
#12 |
![]() Join Date: Mar 2011
Possible clutch chatter, but sounds awful strange. Monster clutches usually don't screw around like that either. Also could be the oil pump gerotor gears, but highly unlikely. Anyways, this is a longshot but do you have A/C? Any chance you forgot about the second belt? As others have said, it really does sound like a pulley.
1997 240SX - DD
1996 240SX - Sold & 2002 Camaro Z28 - Stolen |
