need help installing boost gauge s14sr
So I've done quite a bit of reading. some say best way is to tee it off from the fpr vacuum Line, and some say its bad. Can someone enlighten me on how to install this. Btw its a mechanical boost gauge. Thanks guys
![]() Join Date: Sep 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
I think your post is stupid considering the subject has been covered a bajillion times.
scenario 1: right now fpr vacuum not t'd. How would you know if you developed a leak at the fpr? scenario 2: fpr t'd with boost gauge. You know have a monitoring system installed. Not only for boost, it monitors the vacuum and boost to the fpr. Tap, T or not to T is purely an opinion nothing else, use your big boy or girl decision making skills! It's 2013 wake up! The short version! ![]()
![]() Join Date: May 2009
Location: NYC if i tell you anymore i will need to kill you!
![]() Feedback Score: 6 reviews
It has been covered so many times but none has a definite answer. I have the same problem also, some say T off the FPR and some say to T off the vacumm hose to the wastegate. I would like to know also. And yes i searched all over the forum including nico, 240sxforum, etc. the post starts out good then it is a bullshit people flaming and get side tracked on the subject.
![]() Join Date: Mar 2011
![]() Feedback Score: 8 reviews
I have mine T'd off the W/G vac hose, from what I have read and been told by the shop that tuned my car, the FPR vac lines should not be T'd for any reason.
This from what I understand is to ensure the FPR gets correct signal to do its job, without having to supply a boost gauge also. |
#5 | |
That is what we call false information!
BTW the wastegate doesn't need vacuum to work soooo! you probably have you wastegate hooked up wrong also!
#6 | |
![]() "Tap, T or not to T is purely an opinion nothing else, use your big boy or girl decision making skills"......no big deal then right? Opinion and personal preference?!? "You have to be trusted, by the people that you lie to " Not a Pink Floyd fan then? |
#7 |
So it is definite to T off the FPR. Thanks i have mines running off of my FPR, alsoi wanted to know, my boost controller set at stock setting but when i'm at full throttle the gauge reads 5 psi. Does this mean i have a leak somewhere?
#8 | ||
Here's another: Quote:
