Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Interior & Exterior
Old 01-01-2013, 06:53 PM   #1
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
S13 Center Vent Gauge Plates
  • Fits LHD and RHD S13's
  • Main plate is CNC'd from 1/8" aluminum
  • Inside radius of the gauge openings are beveled so the gauge will drop in when angled
  • ABS angled rings are prepped to remove all casting nubs
  • ABS angled rings are trued on the bottom side as they do not come 100% flat
  • Main plate and rings are texture coated for OEM look
  • Painted with high quality SEM Satin Black
  • Angled plates Include aluminum mounting brackets that can be modified to fit your particular gauge(see pics below)
  • The mounts can also be modified to make a rock solid mounting system for the dash(see pics below)
  • NOTE: All prices include shipping to anywhere in the continental United States. If you are located somewhere else please ask for a shipping quote.
Item: 352 (3) 52mm Gauge Plate: $45 Shipped 1 in stock
Item: 352A (3) 52mm Angled Gauge Plate: $75 Shipped 8 in stock
Item: 260152 (1) 52mm and (2) 60mm Gauge Plate: $45 Shipped 0 in stock
Item: 360 (3) 60mm Gauge Plate: $45 Shipped 2 in stock
Item: 160V (1) 60mm Gauge Plate With Vents: $65 Shipped 1 in stock
Item: 160252 (1) 60mm and (2) 52mm Gauge Plate: $45 Shipped 1 in stock
Item: 252V (2) 52mm Gauge Plate With Vents: $65 Shipped 2 in stock
Item: 252AV (2) 52mm Angled Gauge Plate With Vents: $85 Shipped 4 in stock
Item: BLANK Blank Gauge Plate: $19 Shipped 1 in stock
All Angled Gauge Setups Include Universal Brackets:
The brackets can be cut/modified to accommodate virtually any gauge. This will ensure the gauges do not budge when mounted in the plate. On top of that, the mounting bracket gives you the ability to also make a mounting system to hold the plate to the dash. You can simply tap out the center of the bracket and use some threaded rod to make a rock solid mounting system. I like to cut some aluminum strips to make "washers" and then some simple wing nuts to fasten it in the dash. The wing nuts make it simple to fasten while the dash is still in the car. You can find examples of the modified brackets and mounting system below. Note: I do not sell the mounting system, as it can vary depending on the brand and model of gauge. So I leave that to the consumer if they so choose.
Example of Modified Bracket:
Example of Modified Brackets Mounted:
Example of Mounting System Utilizing Modified Mounting Brackets, Threaded Rod, "Washers" and Wing Nuts:
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline
Old 01-01-2013, 09:22 PM   #2
s14kkouki
s14kkouki's Avatar
s14kkouki is an unknown quantity at this point
That's badass
s14kkouki is offline
Old 01-01-2013, 10:11 PM   #3
heiyuu
heiyuu's Avatar
heiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfection
prolly stoopid questions but would the angled ones work in rhd 180sx
heiyuu is offline
Old 01-01-2013, 10:14 PM   #4
f1gopedder
f1gopedder is an unknown quantity at this point
wouldnt you just mount it upside down?
f1gopedder is offline
Old 01-01-2013, 10:26 PM   #5
Broadfield
Broadfield's Avatar
Yes, you would simply rotate the plate 180 degrees.
My Portfolio
Please Share
Check Out My Builds
Old 01-02-2013, 12:07 PM   #6
Ninjamasta04
Ninjamasta04 is an unknown quantity at this point
I got the one with 52mm angled with vents. Its pretty straight forward installing these and the color matches the console. Very nice products. Thanks Broadfield.
Ninjamasta04 is offline
Old 01-02-2013, 12:20 PM   #7
7jpat
7jpat is an unknown quantity at this point
how about that adjustable vent idea , any work on that yet
7jpat is offline
Old 01-02-2013, 03:42 PM   #8
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Broadfield: its got shit 240s need.
brndck is offline
Old 01-02-2013, 04:37 PM   #9
nickauger
nickauger's Avatar
nickauger is an unknown quantity at this point
link or paypal to order ?
nickauger is offline
Old 01-02-2013, 06:19 PM   #10
Broadfield
Broadfield's Avatar
Thanks for the feedback!
I have not had a chance to research/fabricate any new parts yet. I know that there's not much of a demand for something like that, so it's not at the top of my list. If you want to send me a vent setup and let me take my time with it, I will sell you the outcome for cheap if it works out.
I completely agree!
You can Paypal me at:
[email protected]
Please enter in the comments box what the payment is for and make sure NOT to gift the payment. Also make sure your correct shipping address is associated with your Paypal account to prevent shipping delays.
Thanks,
Toby
My Portfolio
Please Share
Check Out My Builds
Old 01-02-2013, 09:46 PM   #11
khon240sx
khon240sx's Avatar
khon240sx is an unknown quantity at this point
Angled Gauge Plate!!! so sexy!!!!
i'm not even boosted ....one day
khon240sx is offline
Old 01-03-2013, 07:34 PM   #12
Vicious Beaner!
Vicious Beaner!'s Avatar
Trader Rating: (38)
Vicious Beaner! is an unknown quantity at this point
Feedback Score: 38 reviews
any for an s14 ?
Vicious Beaner! is offline
Old 01-03-2013, 07:38 PM   #13
Broadfield
Broadfield's Avatar
Originally Posted by Vicious Beaner! View Post
any for an s14 ?
Well there's no "modular" place to put something like this in an S14.... so no. But I can mold in anything you want in the vent area, ash tray area etc. You can find some examples of my work here:
http://broadfield.wordpress.com/custom-interior-pieces/
My Portfolio
Please Share
Check Out My Builds
Old 01-03-2013, 10:25 PM   #14
240sxracerb25
240sxracerb25 is an unknown quantity at this point
How much for one like this? Would you be able to do 2 62mm and 1 52mm? 62mm are for the greddy d/a multi gauge. Thanks
240sxracerb25 is offline
Old 01-05-2013, 04:37 PM   #15
Broadfield
Broadfield's Avatar
I'm not sure 62mm's are going to fit there. As you can see, 52mm's barely have enough room to fit comfortably. I wouldn't know for sure until I had the panel and gauges in my possession to see how it all lays out.
I stand by the fact that all of my work looks like it belongs and has a nice flow to it. I'm not trying to cram 10 pounds of crap into a 7 pound bag.
If everything "can" fit, then the price would range from $250 - $450 depending on how you want the gauges mounted(angled, flushed, surfaced etc.) and how you want it finished(smooth or textured).
My Portfolio
Please Share
Check Out My Builds
Old 01-07-2013, 07:36 PM   #16
Dutchmalmiss
Dutchmalmiss's Avatar
Dutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfection
Send a message via AIM to Dutchmalmiss
Curious about the 52mm dual angled guage with vent for S13. Do you have pics of this installed?
Pignose, biaaatch.
Dutchmalmiss is offline
Old 01-07-2013, 08:10 PM   #17
Broadfield
Broadfield's Avatar
Sorry, I do not.
My Portfolio
Please Share
Check Out My Builds
Old 01-07-2013, 08:28 PM   #18
bladetech8
bladetech8's Avatar
Trader Rating: (32)
bladetech8 is an unknown quantity at this point
Feedback Score: 32 reviews
Hey Broadfield!
Sent you a PM. Lmk thanks!
bladetech8 is offline
Old 01-08-2013, 02:28 AM   #19
Backintoans13
Backintoans13's Avatar
Backintoans13 is an unknown quantity at this point
Is the blank plate still available?? I talked to you once about it long time ago but erased my inbox one day and lost the email we were talking in lol that and i haven't really worked on my car, if it's available I'll take it! Just need your PayPal
Backintoans13 is offline
Old 01-08-2013, 03:45 AM   #20
Broadfield
Broadfield's Avatar
Originally Posted by bladetech8 View Post
Hey Broadfield!
Replied... thanks for the purchase!
Sure is, you can Paypal me at:
[email protected]
Thanks,
Toby
My Portfolio
Please Share
Check Out My Builds
Old 01-08-2013, 03:46 AM   #21
slickdrifter
slickdrifter is an unknown quantity at this point
Triple gauge angled. Do u have one that fits Haemi gauges? I made a CF one but not angled.
slickdrifter is offline
Old 01-08-2013, 03:49 AM   #22
Broadfield
Broadfield's Avatar
I'm not sure what Haemi gauges are, but if they are 52mm then I don't see why they wouldn't fit.
My Portfolio
Please Share
Check Out My Builds
Old 01-08-2013, 02:51 PM   #23
Backintoans13
Money Sent!! Thanks
Old 01-08-2013, 06:12 PM   #24
Broadfield
Broadfield's Avatar
Money Sent!! Thanks
Thank you sir! It will ship out first thing tomorrow morning!
My Portfolio
Please Share
Check Out My Builds
Old 01-28-2013, 11:21 AM   #25
CptSlippyFist
CptSlippyFist is an unknown quantity at this point
How does one go about installing this in the dash? Trying to replicate how you have pictured.
CptSlippyFist is offline
Old 01-28-2013, 05:21 PM   #26
Broadfield
Broadfield's Avatar
Which plate did you buy from me?
My Portfolio
Please Share
Check Out My Builds
Old 01-28-2013, 06:22 PM   #27
CptSlippyFist
(2) 52mm angled with vent. Do I just rip out all the plastic? I got most of the plastic out of the way but I'm just not sure. I would really rather not remove the dash. Btw thanks for your help.
Old 01-28-2013, 06:32 PM   #28
Broadfield
Broadfield's Avatar
You need to remove the 2 vents by popping each end out with a plastic pry tool or a flat blade screw driver. Once you have the two vents out, you will be able to see the plastic retaining tabs that hold the vent housing/surround in the dash... two on the top and two on the bottom per vent opening. Simply take a 90 degree hook pic and pull the taps inward as you pull/pry out on the vent housing/surround. It will take a little finesse, but should take no longer than 5 minutes. That's all that needs to be removed to install the plate.
My Portfolio
Please Share
Check Out My Builds
Old 01-28-2013, 07:28 PM   #29
CptSlippyFist
...Simply take a 90 degree hook pic and pull the taps inward as you pull/pry out on the vent housing/surround. It will take a little finesse, but should take no longer than 5 minutes...
Simply? Nothing is "simply" done. But thanks, that is what I thought had to be done, those tabs are killing me. Now I get to buy more tools yay. Thanks again!
This guy! Makes awesome custom accessories and helps when you run into problems? Badass.
Old 01-28-2013, 07:47 PM   #30
Broadfield
Broadfield's Avatar
Yeah, it can be tedious with those tabs. You almost need 10 hands so you can pry all of them inward at the same time. Because if you pry it inward and then release the hook pick to move onto the next tab, the first tab will probably drop back in. You may have to pry up a tab, place something thin in there under that tab to keep it out while you work on the next tab. Or, just pry the shit out of the tabs so you essentially bend them inward permanently... even breaking them. I doubt you will ever need to put that vent back in.
My Portfolio
Please Share
Check Out My Builds
angled gauge, broadfield, gauge, s13 gauge pod, vent plate
