Old 03-29-2004, 12:48 PM   #1
Ghettokracker71
Ghettokracker71's Avatar
Ghettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enough
Send a message via AIM to Ghettokracker71 Send a message via Yahoo to Ghettokracker71
s13 sidemarker 'blinky' conversion need help ASAP,I fugged up my blinkers :(!:(:(:(!!!!!!
5) Splice into the *alternate power* wire on the front turn signal, on my car this wire was green, you will splice into this wire using the T-tap, not cutting the green wire, merely making the ground wire off of the turn signal feed into it.
I cut that damned green wire! I cut it before the OEM wiring harness(quick disconnect thingy) b/c the places I went had never heard of a T-tap and I forgot that it said not to cut the green wire,now my blinkers won't work at all,and I need help asap on how to fix it.
I only cut it on the drivers side,after the wiring harness.
PLEASE HELP
I can't drive her without blinkers!!!!!!!!!!!
Ghettokracker71 is offline   Reply With Quote
Old 03-29-2004, 12:53 PM   #2
Ghettokracker71
After trying the green wire in the inline tap with the RED wire(wire to sidemarker) the blinkers didn't work,but the lights do when I turn on my parking/regular lights. I tried reconnecting the green wire without the red wire and the blinker wouldn't work either.
I did the bumper light first,after I had cut the green wire and ran the red(to sidemarker) wire,the blinker still worked before I conected the sidemarker but after I hooked up the sidemarker to the wire from the bumper light(red wire) I lost the blinkers/hazards.
Old 03-29-2004, 01:10 PM   #3
Ghettokracker71
I think if I get a new wiring harness it should work??
Old 03-29-2004, 01:44 PM   #4
mistaanime
mistaanime's Avatar
mistaanime is making a name for him/her selfmistaanime is making a name for him/her self
Send a message via AIM to mistaanime
well...i don't really know wut your talking bout...but all i did was spliced the wires that are connected to the plug to the jdm harness and it juss lit up...and i juss taped up the other plug wit eletric tape.
-Cherry Red 91 Silfourty-
mistaanime is offline   Reply With Quote
Old 03-29-2004, 03:34 PM   #5
Ghettokracker71
Making my sidemarkers blink man....thats what I'm talking about (blinky conversion,the thread blinky blinky?)
Old 03-29-2004, 03:36 PM   #6
Ghettokracker71
I replaced the cut wiring harness,and my blinkers/hazards still don't work. What should I do? Did I blow a fuse or something? I got 2 wiring harness'(thats all they had!) from the junkyard for free,and they both have the same problems. WTF to do
Old 03-29-2004, 04:23 PM   #7
mistaanime
mistaanime's Avatar
wait...does any of your lights work? (Cluster , Climate control)....cuz..when I was doing mah corners...i blew a fuse.....so that could be it..
Old 03-30-2004, 01:22 PM   #8
Ghettokracker71
checked all the fuses....they are fine. My dad and I were wondering if my S13 has a 'flasher' in it or not???? He thinks I blew that....When I tried to turn it on for the first time,it made a noise for a second like something getting fried
Old 03-30-2004, 01:29 PM   #9
mistaanime
mistaanime's Avatar
hmmm bump..heh i nvr did the blinky conversion...there was only one fuse that blew when i was installin them..are any of the lights workin anyways?
Old 03-30-2004, 02:12 PM   #10
Ghettokracker71
All the lights (exterior) are working....thats what gets me
Old 04-02-2004, 01:52 PM   #11
Ghettokracker71
I found 2 blown fuses in the interior fuse panel(driver kick panel) a 15 amp one(hazards) and a 10 amp one(blinkers),so I undid the 'tap wire' connecting the turn signal to the sidemarker,replaced the fuses,got a new harness to replace the cut one,and spliced in the tap wire WITHOUT cutting it,and it blew the 10 amp fuse again...pulled it out,decided to give it ONE more chance,and it blew the 10 amper as soon as it hit the contacts(made a spark,too)
Any ideas??? Blinkers/hazards work fine,my sidemarkers just don't go blinky blinky
