Old 01-09-2013, 01:04 PM   #1
LT_dubs
LT_dubs is an unknown quantity at this point
Clutch to the floor
Yesterday my clutch went straight to the floor and i replaced the slave cylinder and that solved that issue, but today my clutch started getting easier and easier to push in then the clutch went straight to the floor. i cs=ant put it in gear anymore. Clutch failure? maybe? I just replaced the master and slave cylinder and replaced the fluid. I ordered a new clutch a couple days ago before all this maddness started so maybe after the new clutch goes in this will solve everything. help please.
LT_dubs is offline   Reply With Quote
Old 01-09-2013, 01:06 PM   #2
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
u bleed it?
Old 01-09-2013, 01:06 PM   #3
psychos13
psychos13's Avatar
psychos13 is an unknown quantity at this point
did u bleed clutchg and checked line for any leaks?
UNDER DESTRUCTION!: 91 s13 Top Secret Build
psychos13 is offline   Reply With Quote
Old 01-09-2013, 01:08 PM   #4
jdm213
jdm213's Avatar
jdm213 is an unknown quantity at this point
did u check if u left the bleeder valve open
jdm213 is offline   Reply With Quote
Old 01-09-2013, 01:09 PM   #5
LT_dubs
bled it 2nights ago when the slave cylinder took a shit. idk if this counts as a leak but theres like 2 drips on the floor from the last hour or so
Old 01-09-2013, 03:52 PM   #6
SRTFerg
SRTFerg's Avatar
SRTFerg is an unknown quantity at this point
sounds like you are losing pressure in the line. ie. a leak.
Welcome to zilvia, we kick bitches in the face from our high horses.
SRTFerg is offline   Reply With Quote
Old 01-09-2013, 06:20 PM   #7
LT_dubs
No leaks anywhere im completely confused at the moment.
Old 01-09-2013, 06:21 PM   #8
J90lude
J90lude's Avatar
J90lude J90lude J90lude J90lude J90lude J90lude J90lude J90lude J90lude J90lude J90lude
Took the words right outta my mouth.
"Drive it like you running from the cops"
J90lude is offline   Reply With Quote
Old 01-09-2013, 07:08 PM   #9
Greg613
Greg613's Avatar
Greg613 is an unknown quantity at this point
If there's fluid on the ground, even two drips you have a small leak, enough to cause a problem. The master and slave dont actually build any pressure, pumping wont do shit. If it really isn't leaking, check your fork, it is possible that it can come off the release bearing.
I had this exact problem a little while ago, and went through all the trouble shooting. At the end of the day I pulled the tranny and my pressure plate was the cause, some release strapping of metal broke off and caused about 3 fins to get bent.
Greg613 is offline   Reply With Quote
Old 01-10-2013, 07:09 AM   #10
Mikester
Mikester's Avatar
Was one thread not enough?
http://zilvia.net/f/tech-talk/497372...ges-still.html
Old 01-10-2013, 10:49 AM   #11
LT_dubs
Originally Posted by Mikester View Post
Ya That's because I fixed it and a day later it happened again haha
Old 01-10-2013, 11:44 AM   #12
smoked240
smoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymore
Send a message via MSN to smoked240
S13 or S14? The s13 has a block that's added in(can't remember what it's called right now) that connects the clutch master cylinder and slave cylinder. I removed that and all my problems went away. Not sure if the s14 has it though! Goodluck.
smoked240 is offline   Reply With Quote
Old 01-10-2013, 11:52 AM   #13
LT_dubs
Oh ya the clutch damper imma get rid of that as soon as I get home
Old 01-10-2013, 12:31 PM   #14
WESamiss
WESamiss's Avatar
WESamiss is an unknown quantity at this point
While bleeding the system you should check to make sure the slave/throwout fork are moving freely. I've seen a fork brake (on KA-T.org forums) once, strangest thing. If everthing looks good from the outside (pedal assembly, master, slave) I'd pull the transmission off to look and see if the rest of the system is in good working order. Its a super simple system, its all mechanical.
-WES
WESamiss is offline   Reply With Quote
Old 01-10-2013, 12:53 PM   #15
Mikester
Mikester's Avatar
Wipe off all the fluid and verify it doesn't leak. If it leaks, you need to fix it. Also, bleeding the system with that damper loop in there is a royal PITA. You should definitely get rid of it.
Old 01-10-2013, 01:33 PM   #16
vehicle336
vehicle336's Avatar
vehicle336 is an unknown quantity at this point
My clutch pedal assembly just shit the bed the other day. After replacing the slave and master cylinders and removing the transmission and everything checking out, I discovered that the cheap tack weld from the factory failed and snapped. I could still engage the clutch but only slightly and the pedal was almost completely on the floor. Grab a flashlight, get under the dash and grab the pedal and see if you can get the entire assembly to rock back and forth. If it does you just need to swap out the assembly. I'd imagine it's rare as hell, but it does happen.
GL.
May the bridges I burn light the way.
vehicle336 is offline   Reply With Quote
help 240sx
