![]() Join Date: Jan 2011
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
![]() Okay, so i bought a built sr that came with an aem standalone series 1 (pn: 1601) It was already tuned, and in a running car. I took the motor partially apart to verify the build/ make sure everything was good.
I have it in the car, it came pre wired into an engine harness i got with the motor, but i'm having issues starting it. I'm new to AEM's and doing some research on the aem forum i've seen that people have issues syncing the cas to the aem, i followed those steps and changed it from rising to falling, on the crank, verified the mx setting, but when i pull up the engine start it says that the "stat" is off, when it needs to be on for the engine to start? i havn't been approved for the forum yet, so i was hoping some AEM guru's might have some insight on here first so i could get started on trying to figure it out. I don't think i'm getting spark, but when trying to start it with just starter fuid it did shoot a fire ball out of the intake, which it also did after letting the car sit for an hour just when i turned the ignition to on ![]() Info on the motor 272 bc cams ti springs/retainers precision 6262 greddy intake top feed rail, i believe 750cc injectors that i'm assuming are low impedence because they have a resistor box wire in spitfire coil pack setup cp pistons/eagle rods darton 90mm sleeves cas has a clear cover so i'm not sure if it's a hitachi or a mitsubishi (read that the hitachis are the ones with the sync problem) Please no bashing about how i shouldn't have bought a built motor i didn't see run or any of that, i got a really good deal, and it is what it is. Any input would be greatly appreciated, thanks.
![]() Join Date: May 2009
im having a similar problem, but mine starts but drops sync at 2k rpm, ive tried a new CAS didnt fix it, my next step it to try the aem trigger wheel. it just strange because it ran fine before i put a new turbo and cams on it
![]() Join Date: Oct 2007
Just buy a aem trigger wheel it will fix everything
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
#5 |
is the aem registering rpm with the engine off, key on? Its been an issue with the S1 and CAS in the past. mine will do it once in a while, i crank it a bit then try again and itll work
