RB25 acting like a dumb blonde
Ok so i have a RB25DET Series 2. Ran beautiful for months and then the alt. took a crap on me. So i had a brilliant idea to take everything out and do all the necessary things while i had the engine and tranny out. I had the regular side mount and stock exhaust from the ka single cam. After 5 months of getting everything together and ready to put back in. the CEL and the same lights indicating the alt is bad show up right before you turn the engine over. while the engine is running it idles right where it belongs vacuum is at -20. So here's where the problems start
Problems- when revving the engine the idle starts to bog all the way down to the point of dyeing while i drive it and keep it a 3000rpm it will bog down like some sort of fuel cut After revving the idle is inconsistent. when i touch the injector wiring idle becomes a little erratic starting to backfire like crazy as well Solutions i have tried- the unplug method TPS coils injectors MAF Also sprayed brake cleaner around any spot for vacuum leaks no changes in idle Parts upgraded- nissan quest alternator 90mm throttle body Sard FPR gt30 turbo- possibly bad, oil comes out of exhaust yet still builds boost. modified stock turbo manifold w/ tial wastegate 8.9lb spring freddy intake manifold custom downpipe front mount added here is video Jan 8, 2013 7:11pm | Facebook Any help and i will greatly appreciate it. Thank you |
![]() Join Date: Jan 2013
sounds like Vacuum LEAK! also if you are wiggling the injector wires and the idle changes, you could have crappy corroded wiring. but spraying brake cleaner near and injector and the engine changing tone/rpm is clear indication of a vacuum leak check your injector orings
Check the seal from the fuel rail to the Intake Manifold.
Also put an exhaust on the car I hope you're not trying to figure out what's wrong with it with no exhaust. You need some back-pressure on any motor for it to idle and act properly. Especially at lower RPMs etc. If worst comes to worst find someone you can borrow one of these from: Pic of Smoke Base Vacuum leak Tester Or make one lol DIY How-to: build a vacuum leak detection machine - Pennock's Fiero Forum
Like Me on FaceBook ![]() |
#5 |
im gonna check the injector insulators tomorrow wasnt able to work on the car today.
i do have an exhaust its just shortened up i have a stock cat. on it right now |
#6 |
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 4 reviews
First thing, do you have it tuned at all?
Second, rb's are picky little bastards! Does it do it regardless of engine temp? My rb kinda did this but only when it was cold. Was the heating element in my o2. Make sure you have the full length exhaust on, or whatever it was tuned for, if it was. That can mess with the tune.
#7 |
@STEVE SHADOWS the injector insulators were all cracked at the top but not all the way through so i flipped them and the car started to run better after it driving for roughly 15 mins the car started to act up again.
@smoked240 no tune yet. i have the 300zx ecu and maf ready to be put in for the nistune but waiting to put it on. need it to drive right first yes, yes they are mine is the biggest prick i know!!! it now only does this when warm. the exauhst on my rb never mad a difference how much length was on it. i ran mine when i first had it with a stock ka exhaust with the stock cat. lol was very unfindable |
#9 |
![]() Join Date: Mar 2012
![]() Feedback Score: 10 reviews
I couldn't get my rb25det to idle correctly with a q45 TB either. You need a to install your Nistune to get it right, I bought a Haltech platinum pro and it purrs like a kitten.
#12 |
Diagnosing RBs suck. When you say its back firing like crazy it makes me feel like the coils are pooping. Yes the injector seal is an issue but i dont think thats the main issue. The idle could be, but is not limited to, the injector seal, but is it missing at all? I had all the same symptoms youre explaining and it was my coils. For me it would rev perfectly fine but when i would put an actual load on the engine, it would bog. Around 3000-3500 rpm and sounded EXACTLY like a fuel cut. Smell rich, Spit flames the whole nine. hope this helps man. I was in the same boat 2 months ago. Good luck
#13 |
so this is the update of my upcoming install
-injector seals -wideband -nistune -ls2 conversion will give update after these are installed thanks everyone for the help |
240 240sx s13, rb25 |
