Old 01-21-2013, 03:52 PM   #1
240sx-pat
240sx-pat is an unknown quantity at this point
Send a message via AIM to 240sx-pat Send a message via MSN to 240sx-pat
Car REVING on its own as if Im steping on the pendle
I got a weird issue guys. I dont know what happened but while driving and making a right turn and i put the gear in newtural and the shit was reving like crazy I had to turn off the car.he When I turned it back on its just reves as if Im steping on the peddle I need some help with thsi please!
Sorry for all the typos I need to get this thing up and running by tomorrow imma be out side
240sx-pat is offline   Reply With Quote
Old 01-21-2013, 03:57 PM   #2
Veltall
Veltall's Avatar
Veltall is an unknown quantity at this point
check your cruise control module and cable. might be going ape-shit on its own and pulling the cable.
Veltall is offline   Reply With Quote
Old 01-21-2013, 03:59 PM   #3
No 240.. No id
No 240.. No id's Avatar
No 240.. No id is on a distinguished road
Check your throttle cable and disconnect the cruise control cable as well from the throttle body.
No 240.. No id is offline   Reply With Quote
Old 01-21-2013, 04:14 PM   #4
2.5T_/<ouki
2.5T_/<ouki's Avatar
2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice
Im going to vouch for the throttle cable being stuck.
2.5T_/<ouki is offline   Reply With Quote
Old 01-21-2013, 04:38 PM   #5
MrSanchez925
MrSanchez925 is an unknown quantity at this point
its not the throttle cable.
check your TPS and IACV. and clean your TB.
MrSanchez925 is offline   Reply With Quote
Old 01-21-2013, 04:53 PM   #6
2.5T_/<ouki
How can you be so sure? This has happened to me before and the little sucker was stuck on an IC clamp.
Old 01-21-2013, 04:57 PM   #7
240sx-pat
I ended up doing everything cleaning the IACV , INTAKE and the cable...I actually think it was the throttle being stuck now Ive got another issue. my Fuking radiator is leaking god dammmit !! Im going tired of this car!!
Old 01-21-2013, 05:03 PM   #8
Perfect Balance
Perfect Balance's Avatar
Perfect Balance is an unknown quantity at this point
Or check for a huge vacuum leak. Sometimes the car will barely idle and other times it will rev like crazy.
Perfect Balance is offline   Reply With Quote
Old 01-21-2013, 05:44 PM   #9
MrSanchez925
All issues I've.dealt with like that have always been either the iacv or tps.
A sticky cable usually will cause a.high steady idle. Not a bouncy one.
The cable would have to be pulling itself back and forth in order for the idle to bounce.
Old 01-21-2013, 06:34 PM   #10
backccopy
backccopy is an unknown quantity at this point
backccopy is offline   Reply With Quote
Old 01-22-2013, 02:59 AM   #11
cotbu
cotbu's Avatar
I'm not saying you guy's are stupid, just that you haven't seen everything and you answer reflect that.
What I think it is, The coolant temp senor, and it's detecting an over heat situation.
What usually happens is, first high temps, with visual and audible alerts, the audible alert is usually the revving of the engine, visual temp or the rpm gauge up and down in a rhythmic motion.(i know sounds stupid)
If the throttle cable was stuck why would it go up and down, it would be a straight rev to whatever.
Check codes, check for coolant leaks, if none pressure test the coolant system, there are some so repair!
Edit this morning, 3 240 all with sr's two s13 one s14. the symptom up and down idle rpm 900 to 2000. I still believe this to be coolant temp related. My only answer is global warming j/k
Old 01-24-2013, 04:37 PM   #12
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
make sure your throttle plate screws are still in place.
they like to back out.
last time at the track, i was finishing a run and all of a sudden my rpms pegged. redline. instantly i killed the ignition, coasted off to the side and started the car again, as soon as it fired up, bam, redline. instantly i kill the ignition again and we push the car into the pits. pull some piping apart and find that the in the throttle body, where one of the two screws holds the actual throttle plate to the pin that it rotates on, has cracked and the screw is just sitting there inside my throttle body. Fuuuuuuuuuuu that could have been REALLY bad if it had been sucked in.
We ended up welding it, and it's been fine even since, but a large vacuum leak like that will cause your revs to climb excessively.
Old 01-24-2013, 06:14 PM   #13
240sx-pat
That is the exact same thing that my car was doing.THE RPM just started to clime very quickly I freaked me and had me wondering what the #$#w was going on.I pulled over , shut off my car, turned it back on it just climed as soon as I turned it back on.I wasn't very far from my house I decided to drive it home in 4 gear where the RPM was ad a steady 3K.
Like I said the issue is resolved now, I'm still unsure what caused it since I cleaned both the IACV and the throttle plate/body with a shit load of carb cleaner. I did noticed that the Plate was slightly stuck but not too much I'm not sure if it was opened wide enough for the RPM to just shoot up like that.
