Exactly what I wanted to avoid!!
I installed the Eibach Sportline springs on my s13 with KYB's and
I hate you too...
![]() Join Date: Jul 2001
Just wait for the springs to settle.. the front will drop more. 2.5" in the rear is odd though, especially on initial install. Double check the seating on those maybe...
-Jeff
Whatup? |
#5 |
not to be mean or anything but are you sure you installed the right springs in the right their spots, it sounds like you installed the rear springs in the front and the front in the rear.
#6 | |
R.I.P. Aya, always love
![]() Join Date: Nov 2001
Trader Rating: (215)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 215 reviews
"Having a lot of tracks on a song is like putting stickers on a car to get more horsepower" New Video https://www.youtube.com/watch?v=uebV1OnbRsw Buy my mounts! http://zilvia.net/f/sale-items/51531...ns-mounts.html http://zilvia.net/f/tech-talk/317539...e-mouts-6.html |
#9 |
![]() Join Date: Apr 2003
lose some weight and go on the jared plan...wait thatll make you lighter and the front will still be the same
ApexNetwork.Net Sacramento & Norcal Forum |
#10 |
![]() Join Date: Mar 2003
maybe u should try putting the KYB to the lowest settings...so that the springs absorb more? and that way theyre more compressed i guess...it takes a while for springs to settle
#13 |
take out the bodies in your trunk... I'm surprised the smell hasn't got to you already... did you mess w/ the bumpstops in anyway?
does anyone know why the front springs are wayy larger in diameter (w/ the exception of coilovers)... just wondering. |
#16 |
Is there there a reson why the front springs are larger in diameter? I know the fronts are struts and the rear are shocks, but is there a particular reason for the diameter of the front springs?
#17 |
get a picture, i want to see this. I have the sportlines too and my front sits lower and i have over a 100lbs worth of subs and amps in my rear. Front drop is 2.2 and rear is 2.1 claimed by eibach.
#18 |
![]() Join Date: Jan 2002
![]() ![]() Feedback Score: 3 reviews
Just to let you know....
I've been told that you measure the FRAME height. If you think about it, if you were to measure the fenders, i think that would stay pretty constant, just like the frame height. So i dunno....i was told to measure frame height when lowering a car. Any input from the masses? Chris
Member since 2002. (I was here when you were still on Honda-Tech!) |
#19 |
AutoX Junkie
Struts don't have as much travel as a shock, so they use a larger diameter spring to absorb the same amount of force in a shorter distance.
Shock/Strut setting does not affect static ride height. Measure ride height from the kick panel or the frame rail. Our cars have a larger front wheel well for some reason so it can look like it's sitting higher in the front when it's actually even. |
