Old 01-31-2013, 09:57 AM   #1
Silvi
Silvi is an unknown quantity at this point
Sr20det flutter
How can I make it louder like this one?
s14 sr20det flutter - YouTube&fs=1" width="644" height="390">s14 sr20det flutter - YouTube&fs=1" />s14 sr20det flutter - YouTube">http://www.youtube.com/watch?v=s14 sr20det flutter - YouTube
Silvi is offline   Reply With Quote
Old 01-31-2013, 10:17 AM   #2
ultimateirving
ultimateirving's Avatar
you need to make sure to remove the BOV and then make sure u have a t25. once the hard pipes are all sealed u can run the boost up to 1.5bar and as soon as you let off the gas should get a nice amount of flutter.
ur welcome!
Z32 with lq4 swap
Old 01-31-2013, 10:22 AM   #3
Silvi
There is no BOV, I blocked completely the BOV flange
I have GT2876 and all pipes made ​​of aluminum.
Old 01-31-2013, 10:22 AM   #4
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
maybe you should remove the bov and weld the wastegate shut
oh you posted this right after my last post. good job, time to weld that wastegate shut.
Old 01-31-2013, 10:24 AM   #5
ultimateirving
This is the problem, the best flutter is on t25s, and the aluminum pipes act as insulation. u need the plastic stock SMIC piping for maximum sound. Also what Edacious said was good too! it can make all the difference if ur trying to out flutter ur friends
Z32 with lq4 swap
Old 01-31-2013, 10:32 AM   #6
Silvi
Actually im using an 38mm external wastegate and im not sure if the one on the turbo welded.
Im afraid I cant use the stock plastic because of front mount, what about stainless steal?
Old 02-02-2013, 07:24 AM   #7
Silvi
Replacing just the intake aluminium tube with an stainless steal will do the work? :P
Old 02-02-2013, 11:59 AM   #8
OrangeVirus1
OrangeVirus1 is an unknown quantity at this point
I've noticed that Ball bearing turbos don't flutter that loud. my 2871 is quiet even at 10+psi fluttering. compared to some journal bearings i've used
you wants a super loud fluttering turbo? try a K04, they scream when they flutter lol.
I'm actually surprised that this thread wasn't attacted with " get a bov your turbo is going to blow up!" what a relief
OrangeVirus1 is offline   Reply With Quote
Old 02-02-2013, 12:05 PM   #9
Silvi
Heh i'm expected to some comments like you described :P
About the sound - I want it loud as possible but without replacing the turbo
something like this one:
BIG HORSEPOWER JZA80 Supra Turbo flutter mountain run - T04Z 6 speed - YouTube
Old 02-02-2013, 01:27 PM   #10
OrangeVirus1
you need to push alooooooooot of boost
Old 02-02-2013, 01:59 PM   #11
Silvi
1.5 bar of boost is not enough?
I'm hearing something close to this sound, but it's much much quiet
Old 02-02-2013, 02:06 PM   #12
AdamR
AdamR is an unknown quantity at this point
Dose pipe. Dont ask, just look it up.
AdamR is offline   Reply With Quote
Old 02-02-2013, 02:09 PM   #13
AdamR
I've noticed you've mentioned that several times. What are the downsides to using a BOV? I can think of a few for no using one. Sure it may not blow up your turbo, but it does create a lot of forces acting against it, and having one should help transient response.
Old 02-02-2013, 02:13 PM   #14
Silvi
I couldnt find lot of information how to make the sound louder(I made lot of search)
So thats the reason why I asked if replacing the aluminium intake pipe with stainless steal one could be the solution?
Old 02-02-2013, 03:15 PM   #15
OrangeVirus1
shorter the intake on the turbo, the louder it will be. take the intake off completely, it will be really loud
Old 02-02-2013, 05:50 PM   #16
AdamR
msglength
Old 02-02-2013, 06:21 PM   #17
Z33dori
Z33dori's Avatar
ya journal bearing turbos flutter hella loud
i love my BB comp surge tho
