Old 04-04-2004, 08:36 PM   #1
AN89HATCH
AN89HATCH is a well-known jackass
EGR code 32 help
My car is throwing a code "32* EGR function" and my idle is really bad, I have to smog my car next week, can it pass the sniffer with an bad EGR? Where is the EGR located? And what are some of the things I should do to try to fix it thanks The car is a 1989 s13
slide your ride.com
AN89HATCH is offline   Reply With Quote
Old 04-05-2004, 12:07 AM   #2
old_s13
old_s13's Avatar
old_s13 is an unknown quantity at this point
just reset the ECU by unplugging the battery and then plug it back in again. you have an SOHC and the ECU sucks ass, the check engine light never works right.
you may want to do a tune up (plugs, distributor, cap, oil, and o2 sensor) then after all that, take it to pass smog.
- mike
old_s13 is offline   Reply With Quote
Old 04-06-2004, 09:50 PM   #3
Sil-Abc
Sil-Abc's Avatar
Sil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfection
Send a message via AIM to Sil-Abc
heh im having the same problem wit code 32. Wheres the EGR located anyways? i heard its behind the intake manifold but where around it? Does it have 2 tubes on the top that looks like a V shape? thanks
IM JON WAYNE ESQ.... bitch
Sil-Abc is offline   Reply With Quote
