Old 02-19-2013, 03:32 PM   #1
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
Arrow Tons of Aftermarket and OEM parts! NEW and USED! 350z-240sx-WRX-SR-KA-AND MORE!
- If you low ball me even more then I have listed, I won't even respond to you...simple as that.
- If its not listed below, I don't have it for sale!
- Please bump the thread when you view it, thank you.
- I'll add more pictures and more parts soon.
Axxis S13 Ceramic Front Brake Pads
- BNIB
- $40
S14 A/C Bezel
- All tabs are broken
- $10
SR Timing Chain Tensioner
- ~3k miles
- Perfect Shape
- $30
Cam Angle Sensor Gasket and O-ring
- Perfect Shape
- $5
Intake and Exhaust Cam Gear Bolts
- PERFECT SHAPE!
- $3 each
SR20 Head Bolts
- Used
- $15
KU Engineering S13 Intake Manifold
- Never Used (just sitting around for about 3yrs, but the last owner drilled injector port 1 larger to put larger injectors in but then sold it to me...costs about 60 to do it to the other 3 or 40 to correct port 1)
- $110
SR20 Upper Oil Pan - SOLD!
SR20 Oil Pump - SOLD!
SR20 Oil Screens (2 sets)
SR20 Rear Crank Case Cover (4)
SR20 Oil Block Galley w/ Sensor - SOLD!
Unknown Brand BOV
- Slightly Used
- PERFECT SHAPE
- $50
SR Main Cap Girdle
- PERFECT SHAPE
- $15 each
SR Coolant Tubes - $20
SR Short Coolant Tubes - $5
SR Temp. Sensor Housing - $10
SR Thermostat Housing - $10
SR Coolant Inlet - $10
SR Coolant Complete Setup w/ Sensors - $45
OEM SR20VE P11 Valvetrain (IN+EX Valves, Springs, Cams, Gears)
- 15,000 Miles
- PERFECT!
- Valves - SOLD!
Springs - $25
Retainers - $15
Camshafts - $50
Gears - $10
SR20DET AAC Valve
- PERFECT SHAPE
- $30
S14 SR Valve Cover w/ Coil Pack Cover
- Perfect Shape
- $160
stock KA24de airbox intake system and Filter is still clean (came from a 98' kouki)
- PERFECT SHAPE
- $50
S13 Non-ABS Driveshaft - Pick up only
- Used
- $90
S13 SR Transmision - Pick up only
- Roughly 30k miles
- PERFECT SHAPE
- $140
S13 SR20 Intake Gasket
- PERFECT SHAPE
- $10
S13 SR Bell Housing
- No cracks
- $40
S13 SR release bearing
- Good Condition
- $10
S13 SR Clutch Fork
- Perfect Shape
- $20
SR20 Timing Chain guide
- Perfect Shape
- $10
S13 SR Valve Cover Baffeling
- Great Shape
- $10
SR20 Coilpack Gaskets
- NEW
- $3 each
S13 SR20 Valve Cover Gasket
- Perfect Shape
- $15
Injector Gasket O-rings
- Perfect Shape
- $3 each
SR20 Rear Main Seal
- New In Box
- $18
(8) SR20 Hydraulic Lifters
- Perfect Shape
- $5 each
(3) SR OEM Rod
- Great Shape
- $10 each
SR T3/T4 Exhaust Manifold
- NEVER USED
- $90
SR OEM Exhaust Manifold
- Perfect Shape
- $40
SR20det Exhaust Gaskets (t3, T4, Exhaust mani)
- Perfect Shape
- $20
Crank Pulley Bolts (2)
-Perfect Shape
-$5
Transmission Mount Brackets
- Perfect Shape
- $15 each
Nismo KA/SR Transmission mount
- Perfect Shape
- $65
Alternator Brackets
- Perfect Shape
- $20 each
Power Steering Pump
- Perfect Shape
- Missing bracket behind pulley
- $60 -SOLD!!!
Power Steering Pump Bracket
- Perfect Shape
- 30 - SOLD!!!
Knock Sensor (4)...one doesn't have a sub-harness
- Perfect Shape
-$25 each (15 for the one without the sub-harness)
Godspeed Arm - $15
S13 Rear Links - $10 each
S13 Front Lower Control Arm - $30
(2) o2 Sensor Simulator
- NEW IN BOX
- $33
\/ \/ \/ 350Z PARTS \/ \/ \/
350z LSD
- ~15k miles
- $200
350z Master 1 1/16th
- Perfect Shape
- $45
350z Brake Booster
- Perfect Shape
- $100
350z Arms
- Perfect Shape
- $50
350z 03' tinted tail lights
- Great shape
- $75
350z oem Radiator
- ~20k miles
- $100
350z oem Radiator Support
- ~20k miles
- $100
350z Front Bumper
- ~20k miles
- $150
These are all the make an offer items...i dont want or need them so just make an offer...pictures of these upon request.
\/ \/ \/ 2005 WRX (less then 20k miles on items)\/ \/ \/
OEM Air Box Setup
OEM Downpipe
OEM Full Exhaust
OEM Uppipe
OEM Turbo Heat shield
\/ \/ \/ Auto 200SX SER Engine Part Out \/ \/ \/
Head (currently has valves, springs, retainers, and keepers but can remove if buy requests)
Rocker arms
Oil tubes in SR head
Intake and Exhaust cam gears
Valve Cover
EGR valve (in WORKING order)
distributer (in WORKING order)
Headers
Injectors w/ Fuel rail
Intake Manifold (perfect Condition w/ all connectors and hoses)
(3) Pistons
(3) Rods
Water Pump
Water Pump pulley
oil filter block
crank pulley
Coolant tubes
Coolant outlet
Lower Oil Pan
Oil Pan baffling
Timing chain tensioner
Flex Plate
Auto trans gasket
Alternator bracket
intake bracket
power steering bracket
ac bracket
Auto 200sx Engine Harness (completely uncut)
injector harness
tps (throttle position sensor)
Thank You For Looking!
https://instagram.com/eck_matthew/
Imarvin240 is offline   Reply With Quote
Old 03-04-2013, 10:57 PM   #2
Imarvin240
Trader Rating: (18)
Bump it up!
Old 04-14-2013, 07:22 AM   #3
heaterlif3
heaterlif3's Avatar
heaterlif3 is an unknown quantity at this point
message me, [email protected] just saw u already had a pic of it. im away all week on honeymoon. i get back in 8 days. i want that intake manifold . please message me asap my name is Tim Mathieu.
heaterlif3 is offline   Reply With Quote
Old 04-14-2013, 07:41 AM   #4
wrxkid950
wrxkid950 is an unknown quantity at this point
still have the 5spd xmember?
wrxkid950 is offline   Reply With Quote
Old 05-09-2013, 03:45 PM   #5
Supra Hunter
Supra Hunter is an unknown quantity at this point
hit me up... need the sr20 spark plug gaskets for an s13 redtop. do you have the cam angle sensor as well?
Supra Hunter is offline   Reply With Quote
Old 05-13-2013, 01:06 PM   #6
PoorMans180SX
PoorMans180SX's Avatar
You have a PM sir.
Old 05-14-2013, 07:38 AM   #7
-SpOoLiN-
-SpOoLiN- is an unknown quantity at this point
Release bearing have carrier and pin connected to it? Also s13 manual trans x-member still available? Pm me
-SpOoLiN- is offline   Reply With Quote
