Old 02-27-2013, 08:40 AM   #1
nemesisdrift
nemesisdrift is an unknown quantity at this point
FS:Painless Race Car Chassis Harness #50005
Is your chassis harness garbage?? Shorts everywhere, hagged up rats nest? Be a real driver.
"he Painless answer to all your race car wiring needs. Kit includes a fused and relayed 8 circuit fuse block and a 6 switch contour rocker panel to control it. Circuits include: Start, Ignition, Electric Fuel Pump, Electric Water Pump, Electric Cooling Fan, Headlights/Tail Lights, and Two Accessory Relays.
Switch panel measures 8 inches wide X 3 inches tall. Panel is painted black and silkscreened for easy identification of switch functions. Also included in kit is rear chassis for switch panel if roll bar mount is desired.
Parts kit includes all needed crimp connectors for installation of harness and switch panel, 70 Amp Maxi fuse with holder and cover, rubber grommet, 40 Amp circuit breaker for electric fan cooling relay and illustrated installation manual."
Its BRAND NEW. Taken out of the box, put the rocker panel in the car, then sold the shell. I have no use for this soooooo its going up for sale. Save yourself a couple dollars and buy mine!
728$ shipped and that includes FEES anywhere in the lower 48.
PM me !!
nemesisdrift is offline   Reply With Quote
Old 02-27-2013, 08:55 AM   #2
BlewByYou
BlewByYou's Avatar
BlewByYou is an unknown quantity at this point
Wow, what makes this kit so expensive bud?
ARC Flat Touch Switch Panels 8000R is only $280
BlewByYou is offline   Reply With Quote
Old 02-27-2013, 03:08 PM   #3
nemesisdrift
with that you're basically getting just the switch panel and relays.
Old 02-27-2013, 03:42 PM   #4
BlewByYou
BlewByYou's Avatar
Everything is already done with the arc too, Just put one wire to the relay and ground the other wire where ever, Done!
Painless is awesome though but a lil pricey for ur average joe.
