Old 04-09-2004, 04:11 AM   #1
sideviewcivic
sideviewcivic has a little shameless behavior in the past
Send a message via AIM to sideviewcivic
jeopardy:: tech challenge
#1 i noticed only today that during small incidents of spirited throttle, i get the distinctive smell of fuel coming thru the air vents. possible explanations would help.
#2 im trying to get a re-build kit for my ps pump since its leaking along the block and not the hoses .
#3 wiring help on hooking up fal 220 dual fans to work with thermostat and ac relay. since my clutch fan has cracks in it like its about to separate soon .
#4 i've get a very big vibration whenever the rear end starts to get wheel spin. its not just a slight vibration, because the whole chassis shakes violently, when turning left or right when i put the power down. it feels as if the entire rear end is skipping from tire to tire.
#5 i got erratic check light. i dont know whether its the O2 sensor or wut . gonna use diagnostic to find out which code im throwing.
thanx in advance guys.
sideviewcivic is offline   Reply With Quote
