![]() Interested in the following Trades -
S15 SR Head (cams not needed) S15 SR Block (Bare) Fuel Gauge and Sensor/Sender EGT Gauge Complete w Sensor/Probe/Wiring Power Steering Unit S15 Top Mount Precision 550CC Injectors $145 Shipped SOLD to http://zilvia.net/f/members/urnext.html Side Mount 2001 S15 Spec R 480CC injectors $250 obo SR Injector harness with Bosch Style injector Clips $30 SOLD to http://zilvia.net/f/members/urnext.html [IMG] ![]() [IMG] ![]() 2001 s15 throttle body and tps $55 Sitting next to Q45 90mm for comparison [IMG] ![]() Upper coolant hose (blue) with coolant temp sensor and complete wiring $25 Stock S15 Sr20DET Spec R Manifold $65 [IMG] ![]() [IMG] ![]() TURBO SOLD Thanks again http://zilvia.net/f/members/240dream.html Turbo Used less than 200 miles at 9PSI $175 shipped TURBO FOR SALE IS THE t3 with the gold compressor cover For the asking price included An10 45 Degree Hose End for oil return, 5/8 oil return fitting, oil feed with restrictor and Stainless steel feed line and the Polished Aluminum Intake Elbow coupler with 2 new tbolt clamps T3 TURBO CHARGER .63ar Intake: 3 inch Inlet: 2 inch Compressor trim: .50 Compressor Wheel diameter: 50.16 / 76.84 Turbine Wheel diameter: 54.06 / 65.20 Exhaust Trim: .63ar Turbine flange type : T3 flange Down pipe flange type: 5 bolt standard Cooling type: oil cool only Horsepower rating: 350+ ![]() Next to Garret GT 3076r .82 for comparison Apexi Power FC DJetro S15 Sr20DET $350 SOLD to http://zilvia.net/f/members/urnext.html Comes with 3 Bar MAP Sensor Air intake temp sensor Hand Tuner Needs RMA Apexi said cost will be between $125 - $600 if needing complete reman. However after taking to a electronics major he determined the ignition diode need to be replced. The ECU stopped working shortly after being wired in by Portland Speed Industries. ECU still communicates with car and cranks over. I am now running a Haltech Plat pro standalone. RMA Submission [IMG] ![]() ![]() [IMG] ![]() More to come
Drake: 95 Swapped S15SR Z32 Swapped TT 1991Vert Last edited by richmond82; 04-08-2013 at 10:49 AM.. Reason: more parts added and title change |
