Old 03-16-2013, 05:36 PM   #1
Jsicx
Jsicx is an unknown quantity at this point
Need Help Identifying Wires Ka24e
So I need Help in identifying where these 2 wires go.
One is Attached on a bolt right below the valve cover and the other one is attached to what I believe my temperature air sensor, and my ECU also says code 41 which is the sensor.
In this 2nd picture it looks like the air temp sensor might plug into an extra unused wire near the maf (highlighted in the green circle)
Is this correct? and where does the wire that connect near valve cover lead too?
Jsicx is offline   Reply With Quote
Old 05-03-2013, 02:30 PM   #2
Mike Hunt
Mike Hunt's Avatar
Mike Hunt is an unknown quantity at this point
how about some pics, to better identify the wiring. If you have fixed the problem still pics & your solution please.
Mike Hunt is offline   Reply With Quote
