Old 04-14-2004, 11:56 PM   #1
Driving-In-The-Rain
Driving-In-The-Rain is an unknown quantity at this point
4 to 5 lug hub swap question
I only have a quick question regarding a 4 to 5 lug swap on an s14. I have searched the many different forums and search engines with no prevail. Any help is appriciated.
When pulling the old 4 lug hubs is there a special tool needed? And if not, what would be the steps? Thx.
"Theres not a problem that i cant fix.........because i can do it in the mix. and if your man gives you trouble you just move out on the double and you dont let it trouble your brain, cuz away goes trouble down the drain. i said away goes trouble down the drain."
Driving-In-The-Rain is offline   Reply With Quote
Old 04-14-2004, 11:57 PM   #2
DRFT
DRFT is making a name for him/her selfDRFT is making a name for him/her selfDRFT is making a name for him/her self
theres a tool called a hub puller which makes the job easier. i tihnk you can rent it at kragen
ApexNetwork.Net
Sacramento & Norcal Forum
DRFT is offline   Reply With Quote
Old 04-15-2004, 12:09 AM   #3
NinjaGaiden
NinjaGaiden's Avatar
NinjaGaiden is an unknown quantity at this point
this is what i got typing in "5lug swap"
http://www.zilvia.net/f/showthread.p...ight=5lug+swap
You might need a hub puller, but mine just slid right out.
good luck on the swap
NinjaGaiden is offline   Reply With Quote
Old 04-15-2004, 12:46 AM   #4
pinoi007
pinoi007 is an unknown quantity at this point
Buying the rear bearings, i think they are like $90 ea., will make the rear installation alot easier. All you would need to do is remove the whole rear hub assembly + bearings, which the bearings are held by 4 bolts onto the spindles/knuckles, machine or manual press the new bearings and hubs, and put everything back.
The front hubs just slide off. The bearings already come assembled with it.
I did the rears the hard way. My dad and I manually took off the bearings using various tools to chissel at the little gap between the two so they will get pushed apart. Takes a little time but it will work. I can say that they can take a beating. To press the old bearings to the new hubs, we used a long 4x4 wood block and just wack them together. Of course when you hit it, make sure its flush.
We used an axle puller ( can be rented at autozone) on the rears to push the joint/axle inwards because of rust. Also, the 2nd hardest thing about the rears besides manually taking the bearings off is after you take off the 4 bolts holding the bearings, the assembly will still be in place. The bearings are pressed a little onto the spindles. So we used a chissel on the groove between the bearings and hub and tapped it off. The vibrations will make it come loose.
pinoi007 is offline   Reply With Quote
Old 04-15-2004, 05:23 AM   #5
PSI240SX
PSI240SX is an unknown quantity at this point
as stated above, no tool needed. ALso check my thread here: http://www.zilvia.net/f/showthread.p...899#post447899
for additional info on the swap that you may not have known about.
www.enjukuracing.com
PSI240SX is offline   Reply With Quote
