1995 Nissan 240sx SE Vh45de swap
For sale is a 1995 S14 Nissan 240sx SE with a Vh45de swap out of a 1994 Infiniti Q45. The car runs great and is pretty quick. The body is in rough shape but not something that can't be fixed with a little body work and paint. The car starts every time and does not overheat or have any problems. There is a slight oil pan leak but not excessive by any means. I am asking $7500 for the car. I have not drifted this car and really have not driven it too terribly much since completing the swap. You can pick this up, put a little time and money into the body and have yourself a very nice vehicle. This car turns heads at every car meet/event I go to. The sound of the V8 along is enough to get lots a questions at meets and gas stations. I really do love this car, but it is just time to start a new project.
Mileage is 143,xxx on chassis and roughly 120,xxx on engine. Vin: JN1AS44D1SW011840 Car located in Austin, TX 1995 Nissan 240sx SE. VH45de swap out of a 1994 Infiniti Q45 300ZX Z32 transmission Exedy 3 puck clutch Lighweight Flywheel New valve cover gaskets New spark plugs New fuel injectors Mazworx mount and driveshaft kit (one piece steel) Maxworx wiring Mazworx headers ISIS catback exhaust Stance GR coilovers C&R aluminum radiator Nico tuned ECU socketed for Nistune XXR 18x10 +25 front and rear wheels Powered by max 15mm bolt on front wheel spacers Powered by Max adjustable rear upper control arms Powered by Max adjustable toe arms Powered by Max oil pressure and coolant temperature digital gauge Powered by Max oil filter relocation kit with Aeroquip fitting/lines Custom power steering high pressure line Nardi (replica) steering wheel with quick disconnect and slim hub Relocated battery to trunk Sony head unit with pioneer front speakers and Infinity Kappa rear 6x9's but the headunit will need to be wired in Aluminum rear subframe spacers ![]() ![]() ![]() ![]() ![]() |
http://zilvia.net/f/cars-sale/510654...2003-350z.html possible trade? clean title and can be drive on street.
#9 | |
It's Always Broken.
![]() Join Date: Feb 2010
![]() Feedback Score: 14 reviews
Would be awesome if you could get an acceleration video.
240sx, s14, vh45, vh45de |
