Old 04-27-2013, 11:48 AM   #1
T0fuman
T0fuman is an unknown quantity at this point
SR idles but dies when on the road
So ive been having all kinds of problems with the swap i bought. Its 4 years old and the previous owner did nothing but beat on it I guess. It ran fine when the swap was done by a shop and the shop sold it to the guy I bought it from. When i picked it up it took forever to start and had a boost leak. Ive since fixed alot of problems but now have a idle issue. My fuel pressure was not right so I put in a aftermarket FPR with a guage so I could moitor it better. Now when the car comes to a stop at a light or something it just dies. Or when you rev the enine past 2k it just dies. Holds fuel pressure fine and my pump continues to prime so I dont think its fuel. Also just put in new spark plugs and cleaned the IVAC. Was idling around 2k before I did the FPR and plugs so I thought i did some good cause not its a pretty constant 900-1100 idle. When you hammer on the gas the thing takes off like a rocket and spools fine, it will continue to drive as long as you dont let it go back to idling range.
T0fuman is offline   Reply With Quote
Old 04-27-2013, 12:20 PM   #2
ultimateirving
ultimateirving's Avatar
Your iacv is not functioning. Replace or try and see if its not connected properly/wires sharted out
Z32 with lq4 swap
Old 04-27-2013, 01:04 PM   #3
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
Is your BOV venting to atmosphere?
zombiewolf513 is offline   Reply With Quote
Old 04-27-2013, 01:08 PM   #4
T0fuman
BOV is functioning like it should.
Old 04-27-2013, 01:18 PM   #5
zombiewolf513
If you're venting to atmosphere and still using a MAF... that's most likely the cause of your problem.
Old 04-27-2013, 01:20 PM   #6
T0fuman
Well i didnt have this problem before. So i thought it might be something i did? However lots of things are old on this swap.
Old 04-27-2013, 01:33 PM   #7
zombiewolf513
I see. Have a multimeter?
