Old 05-03-2013, 01:06 PM   #1
1jzjoey
1jzjoey's Avatar
1jzjoey is an unknown quantity at this point
Clutch pedal no pressure
hey guys, i have an issue with my clutch pedal on my s13.
First off this car was sitting in a junkyard for awhile, i just bought the car so i have no idea when this problem first started and neither does the previous owner because he never could get the car running, so i bought the car and got it running now im having this issue, i have no pressure in the clutch and it just sits on the floor and wont come back up by itself I have bled the system about 3 times now and still nothing.
Here is what ive tried so far.
-Bleeding the slave cylinder
-Bleeding the dampener box
-Checked the clutch master cylinder (spring is still good)
-Checked the clutch fork and its good
I also checked the slave cylinder and it is kind of weak, as in the rod coming from the slave cylinder that pushes the clutch fork has no pressure and i can push it with my fingers back into the slave cylinder easy as hell, now im not sure if that means its bad or if thats the way it is because theres no pressure in the system.
everytime we bled the slave cylinder the fluid would run out very slowly and not spurt out like it should which again would probably be because of my lack of pressure.
Keep in mind this car has been sitting for a loong time, long enough to clog up the hole in the bleeder nipple(i unclogged the bleeder valve/nipple btw), so maybe the brake lines connecting the system could be alittle clogged and that could be the issue? or could it be the slave cylinder?
all help appreciated.
Originally Posted by 180 drifter View Post
2700 for a non running crashed up car. sounds like a steal.
1jzjoey is offline   Reply With Quote
Old 05-03-2013, 01:13 PM   #2
d_nice
d_nice's Avatar
Trader Rating: (39)
Feedback Score: 39 reviews
i had the same issue and i change the slave cylinder and
clutch master cylinder..i made sure i bleed it well..i hope that works for you.
Old 05-03-2013, 03:15 PM   #3
godsmack
godsmack's Avatar
godsmack is an unknown quantity at this point
Try removing the damper. Basically bypass it and bleed it that way. With the damper in there it will take forever to bleed properly.
godsmack is offline   Reply With Quote
Old 05-03-2013, 03:27 PM   #4
EvilRB
EvilRB's Avatar
EvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond repute
Send a message via AIM to EvilRB Send a message via MSN to EvilRB
Get a new master cylinder and slave just to be safe, they can get old.
I would just to be safe anyway...
and remove the damper
Here is a link to the DIY
THE GARAGE GUIDES - Remove Your Clutch Damper
and a youtube vid: Clutch Damper Box Removal - YouTube
gay but it works
or get this fitting :
good luck!
EvilRB is offline   Reply With Quote
Old 05-03-2013, 05:14 PM   #5
1jzjoey
1jzjoey's Avatar
you're absolutely right, I just came back in to tell everyone my solution.
I bypassed the damper box and it only took about 5 minutes of bleeding to get my clutch back. What a relief!
Old 05-03-2013, 06:28 PM   #6
EvilRB
EvilRB's Avatar
What I get no love?
I provided the links?? HAHA!
Nah I'm glad you got it to work!
Old 05-03-2013, 06:51 PM   #7
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
Well, there's two ports on the dampening box for bleeding.
Its useless, so good for you to take it off.
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
Old 05-04-2013, 08:47 PM   #8
1jzjoey
1jzjoey's Avatar
Originally Posted by EvilRB View Post
What I get no love?
shout out to you too breh, i had it fixed before i even saw both of your replies though. haha
