Old 05-06-2013, 10:15 AM   #1
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
Wiring issue? Fans on without key in ignition.
So this winter i redid the timing belt/water pump and new gauges. and a few other small things on the 2JZ 240sx. Went to start checking things over and decided it was time to turn the ignition on. So i hooked up the battery and as soon as the battery had power/ground the electric fans turned on (Flex a lite 410s, Controlled by a DIF PWM fan controller). I thought that was odd i went ahead and bumped the key to ACC and the fans shut off. I wired the fans/controller the same as they were the previous year (in good working shape then, following the instructions posted by DIF and FAL.) When i turned the ACC off the fuel pump stayed running.
I'm not sure if something is grounding out somewhere in the harness. Or if it is an ignition switch issue that it doesn't know what key on/key off is. Or if the battery just doesn't have a good enough charge (although it was reading 11.8-12.1 Volts) Or if it is a relay issue? I'm going to be checking it again just wanted someone elses opinion.
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
