Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Engine
Old 05-10-2013, 01:30 PM   #1
Enjuku Racing
Trader Rating: (29)
Enjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to beholdEnjuku Racing is a splendid one to behold
Feedback Score: 29 reviews
Send a message via AIM to Enjuku Racing
Enjuku Racing - GKTech Replacement Engine Fans - SR/KA ** IN STOCK **
http://www.enjukuracing.com/products/GKtech-Replacement-Engine-Fan-%252d-Nissan-S13%7B47%7DS14-240SX-%26-Silvia.html
GKtech Replacement Engine Fan - Nissan S13/S14 240SX & Silvia - Enjuku Racing Parts, LLC
The GKTECH replacement engine fan has been designed and engineered in Australia specifically for us with the intention of pulling more air than the factory item. Surprisingly, this was very easy to design and the design that our engineering firm came up with is based around the design of a propeller. It is a direct replacement clutch fan for the S13/180sx, S14 and S15 SR20 powered Silvia's/200sx's. Simply remove your factory fan (4 bolts) and install the new fan.
- Direct replacement of the standard fan
- Pulls 60% more air than the factory SR/KA fan and pulls around 40% more air than the factory RB25 fan (a common upgrade)
- When tested on a dyno the new fan took less than half the time to cool down from 90 degrees to operating temperature (good for next time you're on the start line at the track)
- Only a slight increase in noise (barely noticeable)
These Will fit S13/S14 Cars with SR20DET or USDM Cars with KA24DE
Vehicle Compatibility:
Nissan Silvia S13 (SR20 & KA24)
Nissan Silvia S14 (SR20 & KA24)
Nissan 180sx
Nissan 200sx S14
Nissan 200sx S15
FREE SHIPPING! to USA and Canada, all other locations will be charged shipping expenses.
IMPORTANT Notice to customers: GKtech products are typically(but not always) shipped to you directly from the manufacturer in Australia, therefore shipping times may take anywhere from 5 to 14 days. please be aware of this extended delivery time when placing your order.
What's the advantage of having more air flow?
We tested the clutch fan on a test vehicle in a controlled environment (on a dyno) with back to back tests and from 90 degrees celcius it took less than half the time to go from 90 degrees to idle operating temperature.
Will this fit my car?
Please refer to the confirmed vehicle list in the item description. We do not sell any items that aren’t listed on our website and if we haven’t confirmed fitment on your car, then we don’t know if it will fit or not. Please do not ask.
How do clutch fans compare to thermo fans?
If you've ever been to the track with thermo fans you know that unless setup with a shroud and setup correctly, they're useless. Clutch fans with the standard shroud are the way to go.
What's the weight on the clutch compared to the standard item?
The standard clutch fan is 415mm's in diamter and weighs in at 640grams. Our new design is 430mm's in diameter and coincidentally also weighs 640grams.
What is the clutch fan made of?
The clutch fan has a metal center (like the factory unit) and is made of ABS plastic (like the factory unit).
Will I lose any engine power with the fan pulling more air?
No, with our dyno tests on the same car within 30 minutes of each test with multiple runs made we actually GAINED around 1% in power with the new clutch fan installed. The cause of this? There was less heat soak and everything was running cooler.
This all sounds too good to be true!
This isn't rocket science but we'll let you be the judge. Try it out, guaranteed 100% it'll blow you away (see what we did there! ha!). But seriously, this is one of our favourite products and before you go any buy any other cooling related parts, this is the one that will make the biggest difference.
Office: 352-241-8399 / 1-888-SR20DET (772-0338)
YouTube.com/c/EnjukuRacingParts
[email protected]
Enjuku Racing is offline   Reply With Quote
Old 05-10-2013, 06:31 PM   #2
ghetto180
ghetto180's Avatar
ghetto180 is an unknown quantity at this point
clutch fan
how much thank you, n ur paypal please
ghetto180 is offline   Reply With Quote
Old 05-14-2013, 07:50 AM   #3
Enjuku Racing
Trader Rating: (29)
Just sent you a PM.
- Sam
[email protected]
Old 05-21-2013, 09:46 AM   #4
Om1kron
Om1kron's Avatar
cool just ordered one.
Wayne Edwards
https://om1kron.blogspot.com
Old 05-22-2013, 12:58 PM   #5
Enjuku Racing
Trader Rating: (29)
Awesome! Thank you for your purchase.
- Sam
[email protected]
Old 05-22-2013, 01:27 PM   #6
foxystyle
foxystyle's Avatar
foxystyle is an unknown quantity at this point
Just ordered! Thank you enjuku!
foxystyle is offline   Reply With Quote
Old 05-31-2013, 11:19 PM   #7
EmporioJason
EmporioJason is an unknown quantity at this point
That's Really one spectacular piece and in-fact i did ordered one too . .
limo services | sydney limousine | sydney limousine service
EmporioJason is offline   Reply With Quote
