Old 05-11-2013, 05:12 PM   #1
Dreyvius
Dreyvius's Avatar
Dreyvius is an unknown quantity at this point
Clutch is different after trans oil change
I changed out my trans oil to redline MT 90, no clue what was in it before. had to replace rear trans seal. And now my clutch is engaging when fully pressed in and it engaged before when close to fully depressed. Was there something i was supposed to do but didnt or wtf happened? Its a 92 240 with sr swap and stage 3 clutch
Dreyvius is offline   Reply With Quote
Old 05-11-2013, 06:28 PM   #2
dawagarage
dawagarage's Avatar
dawagarage is an unknown quantity at this point
did you bleed the hydraulic system after you drained/disconnected your slave cylinder?
formerly known as "hotboiblaze"
ratsun: dawa (73 datsun 620)
clublexus: properD (97 sc300)
dawagarage is offline   Reply With Quote
Old 05-11-2013, 06:31 PM   #3
theman7291
theman7291 is an unknown quantity at this point
Is it a pull style clutch
Sent from my SPH-L900 using Tapatalk 2
theman7291 is offline   Reply With Quote
Old 05-11-2013, 06:42 PM   #4
S12 Drifter
S12 Drifter's Avatar
S12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymore
I'm going to take a stab and say your master took a poop.
Originally Posted by S13slida View Post
Your wife has bigger balls then you.
S12 Drifter is offline   Reply With Quote
Old 05-11-2013, 07:45 PM   #5
Dreyvius
Dreyvius's Avatar
i only changed out the transmission fluid, nothing else. after driving it around a bit more its slowly going back to normal. should i still be worried or do i need to do anything extra? never heard of anything more needing to be done with a trans fluid change
Old 05-11-2013, 07:57 PM   #6
Dreyvius
Dreyvius's Avatar
it has had no conversion done to it, and 240s are normally push style right? its a SPEC 6 puck stage 3 clutch. what are you getting to if its either push or pull, what changes here with the situation? i dont know mush about the differences, i just know they both exist
Old 05-11-2013, 07:58 PM   #7
Dreyvius
Dreyvius's Avatar
well its getting better over time it seems, so thats good right? lol... ugh i hope
Old 05-11-2013, 11:22 PM   #8
dawagarage
dawagarage's Avatar
ah i thought you mightve pulled the trans to replace the seal so i assumed you removed the slave
Old 05-12-2013, 02:41 PM   #9
derass
It could possibly be seals in the master or slave starting to leak, the system in need of a bleeding, or old fluid. The clutch system uses brake fluid, which should be changed every 2 years.
That, or it's all in your head.
Old 05-12-2013, 02:43 PM   #10
Dreyvius
Dreyvius's Avatar
youre probably right and yes its around that time for fluid change, its back to normal now but still gonna change it
