Old 06-03-2013, 11:44 AM   #1
Ramonesfreak2010
Ramonesfreak2010's Avatar
Ramonesfreak2010 is an unknown quantity at this point
FS: SR20DET Black Top Swap & Part out! PBM, Fidanza, Kouki Tails, Spec, Earls
Tom
2404946341
Text only
Pick up only
NO trades
Columbia, MD
I've got for sale a pair of green/blue S14 seats. In great condition. No burns or tears. The plastic piece is missing on the recliner lever thing on the driver side. Has a few stains. Could use a good cleaning. Asking $125 for the pair
Don't mind Larry.
My prices are FIRM. I have no time for low ballers, etc. These are quality parts. Not eBay shit.
**NOTE: WILL NOT SELL ANYTHINGS UNTIL THE MOTOR GOES FIRST**
S13 SR20DET Black Top: $1,800 for motor, trans, converted harness for 89-90, ECU, MAF, & stock intake tube. (Does not include flywheel, or clutch) All you would need for a complete swap is a downpipe, intercooler, clutch, and flywheel. I bought this at Japanese Engine Import back in January. Has been running since with no problems at all. It'll start up every time. Has multi layered turbo and turbo manifold gaskets. It shoots out a bit of smoke once in a blue moon. Could be the valve seals. Last I did a compression test, it was 150psi across the board. If you have a compression tester, feel free to come test it out. Other than that, the motor is solid.
Powered By Max Cobra pipe (its a little dirty from dirt. Just needs a good cleaning): $250
Spec Stage 3 Clutch: $200
Fidanza Flywheel: $350
PBM HMIC: $350
Kouki Tails already converted for USDM harness (two studs are broken, and the bulb housings were fucked up, so I bought aftermarket ones and modified to fit. Works perfect: $350 PENDING
Custom fuel lines (Looks like Chase Bays). Made these myself with -6 AN lines and fittings. Comes with filter. No leaks whatsoever: $150
Pignose Lip (no cracks. Needs paint tho): $50
*not pictured*
[/align]
Ramonesfreak2010 is offline   Reply With Quote
Old 06-03-2013, 12:12 PM   #2
Adam496
Adam496 is making a name for him/her selfAdam496 is making a name for him/her selfAdam496 is making a name for him/her self
if you do decide to ship ill take the flex cobra
Adam496 is offline   Reply With Quote
Old 06-03-2013, 02:28 PM   #3
[email protected]
Paul@mastermindna.com's Avatar
Paul@mastermindna.com is an unknown quantity at this point
Bump for strong motor and good seller. I saw this motor run in person and it ran great. GLWS
Paul@mastermindna.com is offline   Reply With Quote
Old 06-04-2013, 07:45 AM   #4
jroy1234
jroy1234's Avatar
jroy1234 is an unknown quantity at this point
would you ship the IC?
jroy1234 is offline   Reply With Quote
Old 06-04-2013, 09:00 AM   #5
jrm87
jrm87 is an unknown quantity at this point
text sent about S14 seats.
jrm87 is offline   Reply With Quote
Old 06-06-2013, 10:18 AM   #6
Ramonesfreak2010
Seats are gone.
Motor w/ trans, HMIC, and downpipe pending.
Kouki tails pending.
Old 06-17-2013, 08:10 AM   #7
James.Michael.USAF
James.Michael.USAF is an unknown quantity at this point
what BOV are you running on HMIC? is it still available?
James.Michael.USAF is offline   Reply With Quote
