Old 06-09-2013, 04:26 PM   #1
pelliccio77
pelliccio77 is an unknown quantity at this point
KA 1985 AE86 Corolla GTS coupe drift project
Up for sale or trade is my 1985 AE86 Toyota Corolla GTS Coupe with a clear blue title.
Will trade car for other drift vehicles or some baller 5x114.3 vip wheels. Trades may involve cash on either end depending on the value of the item.
Not a stock part on the car everything is aftermarket tons of custom work!
The motor is not getting spark and it is wiring related. I have decided to move on to another project.
Call or text me @ 3187513323 with interests or trade offers. My name is Tony, thanks
Motor and Drivetrain:
-fully rebuilt 92 ka24de engine (3k miles)
-godspeed intake manifold
-tubular turbo exhaust manifold
-t2 flange
-blue vas racing 10.2mm spark plug wires
-denso iridium spark plugs
-single belt conversion
-blue 90 degree silicone adapter, 3" aluminum piping with specter filter
-15 gallon aluminum fuel cell
-90lph 3 bar external fuel pump
-magnaflow dual resonated exhaust (needs exhaust ran from manifold to resonators)
-full wire tuck
-exedy stage 1 clutch
-freshly turned stock flywheel
-twin core aluminum radiator
-2 electric flat fans
-b&m replica short shifter
-one piece driveshaft
-solid crush sleeve by weir performance
-welded diff (having issues)
-oem spare rear end w/lsd
Suspension and Footwork:
-custom fitted knuckles for excessive steering angle
-custom front lower control arms for extreme camber
-manual steering rack
-manual rack inner tie rods
-battle version rack spacers
-urethane lower control arm bushing
-urethane tension rod bushing
-urethane front and rear sway bar bushings and end links
-urethane 4 link bar pushings
-godspeed lateral bar
-TRD style camber plates
-TRD front 8kg springs
-TRD rear 6kg springs
-KYB AGX front and rear dampening adjustable shocks
-rear steel braided brake lines
-rear drilled and slotted rotors
-hydraulic handbrake (ebrake)
-300zx brake booster
-performance options brake booster delete
-brake line tuck
-XXR 527 15x8 wheels
-brand new continental tires 175/55/r15
-rear strut tower bar
Exterior, Interior, and Chassis work
-uras style front bumper by VIS
-vertex style side skirts
-vertex style rear bumper
-custom front bash bar/tow away bar
-custom rear bash bar w/tow hook
-zenki tail lights
-custom headlight covers
-shaved key locks
-illest license plate
-detachable front and rear bumper latches (removable in seconds
-detachable trunk latches
-custom square mirrors
-custom square tubular front end support
-custom quick detach core support
-cut wheel wells for clearance
-custom round tubing bracing supports
-custom door bars and chassis support
-bride low max seats (brand new)
-green sparco style harness
-harness bar
-custom sticker bomb door panels and dash covers
-custom shifter cover w/sticker bomb
-crown royal tan suede shift boot
-custom gauge pod
-wink mirror
-deep dish sparco style steering wheel and hub
-equus water temp gauge, oil pressure gauge, tach gauge, voltage gauge, fuel level gauge
-battery relocation
-150 amp battery breaker switch for easy off/on
-panasonic battery
Misc.
-brand new windshield
-tag along toe bar for towing
-switch panel for gauges
-baller enormous wheel spacers front and rear
-sunroof delete
Issues
-ka needs wiring work to get spark to the motor
-rear end may need to be changed before driving it is whining but thats what the spare is for
-exhaust needs to be ran from the exhaust manifold to the resonators if you are going n/a
-hood is primered and cut to clear large radiator
Goods:
Everything is there and works. the engine is just not getting any spark. the ecu does have power. I bought it from the guy who put the motor in it. My plan was to ask my buddy with ka wiring experience to help me out but he does not have time to get it running. I am tired of looking at it and am ready to move on to something else. Someone with wiring skills should buy this car and it will be an easy and free fix. The motor turns over like it should just no spark!
pelliccio77 is offline   Reply With Quote
Old 06-09-2013, 04:58 PM   #2
pelliccio77
http://i1268.photobucket.com/albums/...io7/null-5.jpg
Check out the pictures here. I couldn't get it to work on my phone sorry.
Old 06-09-2013, 11:26 PM   #3
SupaDoopa
SupaDoopa's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
Wrong section. MODS, move to cars for sale.
Ironic, doe. This looks almost exactly to a local friend. He has a AE with a KA swap. Small world.
SupaDoopa is offline   Reply With Quote
