Wanted to Buy Post your needs and wants here. |
Looking for a boosted 240 in South FL
title says it all if you have anything text me a link to
I will most likely lose track of this post so dont reply here Last edited by Nissan2nr22; 12-06-2018 at 11:52 AM.. |
#2 | |
GM2 (SW/AW)
What exactly are you looking for? a KA/SR/RB/CA ?
Hatch or coupe? maybe a vert? What kind of price range?
KA-T for life! Current for sale advertisement ![]() |
![]() Join Date: May 2013
Don't know If you're willing to drive to Tampa (I doubt it) but I found this nice 95' coupe for 2500$. But...Its automatic.
![]() http://tampa.craigslist.org/pnl/cto/3895572246.html |
#7 | |
Power steering is connected, I had to change the a/c line waiting to get the a/c charged hopefully this week but was working before the line. Here is the list of stuff done. Engine: Jim wolf s3 cams Greddy rocker arm stoppers Tomei expream turbo manifold S15 GT28r turbo RAW 3" turbo back exshaust V-band clamps 2 magnaflow mufflers 300zx Maf R.S. Enthalpy tuned ecu MSD 50Lb top feed injectors RAW top feed fuel rail Aeromotive fuel pressure regulator -6 fuel push lock fuel lines feed and return Walbro in tank fuel pump 3" x24" x12" intercooler, Intercooler piping done at RAW RAW intake pipe Greddy blow off valve recirculated K&N air filter working A/C and power steering Koyo radiator Ford Taurus electric fan FAL fan controller with A/C control HKS DLI Freddy oil pan Drive train: Act Hd 6 puck clutch Spec 14lb flywheel shaft masters 1 piece aluminum drive shaft Nismo slave cylinder Nismo Trans mount 4.36 LSD rear end Transmission has bad syncros in 1st and 2nd but I have a spare transmission that goes with the car LSD is funky have s14 open diff to go with car Brakes and wheels: z32 26mm front calipers and rotors with Hawk HPS pads Stock rear calipers Carbotech pads Stainless brake lines front and back SSR 15" reverse mesh wheels Suspension: Megan racing arms in the rear Ruca, Traction and Toe KYB adjustable shocks and lowering springs Energy supension s14 rear subframe bushings Modified to raise subframe up Body and interior: 1992 White s13 coupe base model No spoiler Black and gray interior Uncracked dash pionner head unit with pionner speakers all around. AEM wideband Autometer gauges Oil temp, Oil pressure, Water temp and Boost pressure Mounted in a custom gauge panel in glove box I think that is everything. |
#8 |
![]() Join Date: Mar 2009
![]() Feedback Score: 13 reviews
you can give a ball park on to how much ur looking to spend. i dont want to waste your time or mine if your not even close to what i am asking for my car.if your in the 5k range you arent close to buying my car. if ur in the 15k range then maybe i might text u some pictures and we can talk.
