![]() Pm me for questions and whatnot
Willing to ship - NA Vg30de Twin cam 24 valve - 5 speed manual - 2 seater - 132,xxx miles. I drive it on weekends. - ZERO RUST - Brand new OEM brake rotor and pads. They squeal because i forgot to take off the film of the rotor - Brand new OEM radiator - Brand new OEM water pump - Brand new timing belt. They squeal at cold start up, didn't tension it harder but goes away instantly. - Brand new tie rods - Brand new fuel filter - Brand new coil packs - Brand new platinum Bosch spark plugs. I have OEM NGK plugs in good condition i will throw in. - Brand new tires. Im selling it with the OEM wheels but if you want the ones in pic, 1300 extra cause they're brand new all season rubber. New and balanced. - AFTERMARKET Injen high flow ram intake and filter. - AFTERMARKET Eonon screen with back up camera. AUX, Bluetooth, DVD, Radio (antenna doesnt go all the way up but plays stations. - SELLING WITH OEM RIMS WITH BRAND NEW RUBBER CONS: - The paint in some areas bit rough - The trim color is coming off, probably from the Arizona sun. - The gearbox is bit rough - The Antenna does not go up all the way. but it works - The driver side lock is broken. You have to open passenger to get in - I took the OEM rear wing off because the paint was really bad and ruined the look, and sealed the holes on trunk. If you want the wing ill give it to you. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by Phantogram; 08-22-2013 at 12:44 PM.. |
300zx, nissan, slicktop, z32 |
