Old 06-25-2013, 05:48 PM   #1
GundamZero
GundamZero's Avatar
GundamZero is an unknown quantity at this point
Starter Issues. Short Clip
Can anyone please help! My starter is just clicking rapidly. I have charged the battery, tried jumping it from a running car, checked grounds, and added another ground from starter to chassis. Engine spins by hand, fuel pump primes, etc. S13 Blacktop SR in a 1991 240sx.
Here is a short video, please take a look!
http://www.youtube.com/watch?v=S8ZkYWnTfIA
Thanks in advance for any help!
GundamZero is offline   Reply With Quote
Old 06-25-2013, 06:02 PM   #2
LayNLow
LayNLow is making a name for him/her selfLayNLow is making a name for him/her self
Sounds like your battery is dead. Try swapping it with another known good battery. If the starter died it would just click once and not turn over. If it still does it with a good battery its probably the starter relay.
LayNLow is offline   Reply With Quote
Old 06-25-2013, 06:24 PM   #3
GundamZero
GundamZero's Avatar
I charged the battery and I tried another battery, ill check out that relay. Thanks
Old 06-26-2013, 02:25 AM   #4
steve shadows
steve shadows's Avatar
After you check the relay if it still does it make extra sure none of the bolts loosened up holding the starter to the tranny case. Also moderately tab the side of the starter with a rubber mallet or lightly tap it a few times with a hammers...sometimes it get's jammed against the flywheel...sometimes when the gear is wearing out on it. But this should get you going. gl
Like Me on FaceBook !
Old 06-26-2013, 02:38 AM   #5
millerlight763
millerlight763's Avatar
millerlight763 is an unknown quantity at this point
Send a message via AIM to millerlight763
Had that problem with my 2nd 240. Either a fried battery or your starter is done. Good Luck
Keep Calm and Chive On
Originally Posted by Piggy View Post
You need to learn how to pull the handbrake. If you do it right, girls' clothes will come off.
millerlight763 is offline   Reply With Quote
Old 06-27-2013, 03:41 PM   #6
GundamZero
GundamZero's Avatar
Ok thanks for all of the help guys! Looks like I need a new starter, which brings up another question. Can I rebuild my SR starter with parts from my working KADE starter? Thanks again guys I really appreciate the help!
Old 06-27-2013, 05:06 PM   #7
GundamZero
GundamZero's Avatar
Never mind, I just got back from getting the starter tested, it passed a few times with flying colors. Anything else to check? Thanks guys.
Old 06-27-2013, 05:47 PM   #8
zeebrah
zeebrah is an unknown quantity at this point
Check grounds/connections. If not its forsure theStarter relay.... or sometimes called at auto part stores 'clutch interlock switch'
Its a little blue box that causes 90% of starting issues on 240s. If they cant find it under that name sesrch around google for the actual part number (this happened to me and they claim the part didnt exist untill I found the part number online) like under $15 from vatozone. Go do it
Braaap
zeebrah is offline   Reply With Quote
