Old 06-29-2013, 08:24 PM   #1
nutz240sx
nutz240sx is an unknown quantity at this point
steering shaft to rack leak?
Searched for a little while with no luck on what I'm looking for.
I have a slight power steering leak, finally found where it was coming from and I'm trying to decide how to go about it.
The leak is coming from where the top of the valve housing/gear housing or whatever the proper name for it is (red arrow in the picture below). Looks like there is a o-ring or something there where its seeping out of.
Is that housing (circled in red) where the 4 hard lines run into removable and/or replaceable? Or should I just get a whole new rack and pinion.
I haven't really found any parts other than the whole rack or tie rod boots.
Any advice?
nutz240sx is offline   Reply With Quote
Old 06-29-2013, 08:36 PM   #2
a fuzzychnchila
a fuzzychnchila's Avatar
a fuzzychnchila is an unknown quantity at this point
I had the same leak... Replaced it with a rebuilt rack... no leaks now
a fuzzychnchila is offline   Reply With Quote
Old 06-29-2013, 09:30 PM   #3
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
I spent soem serious time searching for that O ring, but wasn't able to find a replacement. Different rack or a rebuilt rack is the only way to solve the leaking issue.
Old 06-29-2013, 09:31 PM   #4
2tonecoupegrl
Trader Rating: (134)
2tonecoupegrl is an unknown quantity at this point
Feedback Score: 134 reviews
Sent you a private message..
Need some parts? Send me a message!
2tonecoupegrl is offline   Reply With Quote
Old 06-30-2013, 12:46 AM   #5
nutz240sx
Thanks for the tips, guess ill just get a new/rebuilt rack. Not a big deal.
@2tonecoupegrl - i pm'd you back. Thanks tho
Old 06-30-2013, 01:45 AM   #6
2tonecoupegrl
Replied to you!
Old 06-30-2013, 08:10 AM   #7
tobroketobuildarealcar
tobroketobuildarealcar is an unknown quantity at this point
I also had the same problem and went with the rebuild rack
rock auto.com sells rebuild kits for about 50 bucks but I was afraid it did not have all the parts I needed
tobroketobuildarealcar is offline   Reply With Quote
