Old 07-04-2013, 12:20 AM   #1
Jfornachon
Jfornachon is an unknown quantity at this point
Socal 1990 s13 s40 coup ft end damage xtra parts
I would like to sell the car as a whole as of now. I will only sell what is not on the car separately. Feel free to text on my cell 31074077one6. I would like 6k for the car and 10k for everything that I have listed and anything else that I forgot to list. I can also send pictures via text.
S14 sr20det w/Wiring solutions upper and lower harness, ACT streetlight flywheel, and stage 1 clutch, Nismo thermostat, Circuit sports engine pullys
Greddy Down Pipe, Megan 3in cat delete and Duel Tip esxhaust
Koni race front, Veilside housings front, koni yellow rear, Tein upper hats ft & rr, gc sleves and springs, Tein helper srings rr.
Whiteline racing adjustable front sway bar.
Mishmoto radiator and duel fans w/DIF fan controller
Autopower roll bar
New ps rack in the last year with new outer tie rods
300xz brakes ft and rr with dif ss lines (w/parking brake cables not installed)
New clutch system with full ss line
Circuit sports suspension ft and rr arms except lower ft and rr
Nismo Power brace
Circuit sports sub frame collars
Alutech ft strut brace
S15 Helicle diff w/6 bolt axels
Spare rebuild able sr trans
Nismo Motor mounts and trans mount
Stack boost guage mounted on duel pod steering column.
Kenwood Sterio, Kenwood components up front, Blaupukt 6in sub p-side rr floor, and Pioneer rr deck speakers.
Ichiba Hubs w/ miata extended arp studs and 8mm spacers and S14 5 lug wheels 24 17mm steal lug nuts, extra spare studs, 20 19mm aluminum lugnuts
FR sport fuel pressure in line gauge
Trunk relocated battery No a/c, crank windows, two very small cracks on dash, $80 windshield sun visor Original harness, xtra coils and ignitor, Factory hood, front bumper, hood latch, and p.side headlight assembly Any and all OEM parts that I have including original calipers and ss lines and misc interior parts.
240 sx extra parts
Not on the car
Aem standalone with patch harness pre wired with map, o2, ita, clutch switch (all sensors included) MAC EBC not wired in yet.
3 gauge a pillar pod w/oil psi, oil temp, and coolant temp w/ Circuit sports oil filter sandwich plate, 2nd gen rx7 thermostatically controlled oil cooler
Greddy turbo outlet pipe/ o2 housing NEW
S15 turbo (very slightly used will need to clock it will explain if interested) also SS feed lines and restrictor for bb turbo
Factory gasket kit minus v/c gasket NEW
Factory timing chain kit NEW
Factory Oil pump NEW
ATE super damper
AEM AFPR
I am sure there are parts that I am missing. We can make a deal on everything, Please take note this never saw the track and lots of parts are fairly new.
Have a great day,
Jared
Jfornachon is offline   Reply With Quote
Old 07-10-2013, 04:14 PM   #2
Jfornachon
This has turned into a complete part out. The above listed parts are for sale as well as all other parts front end body is toast. Rear end is good condition trunk lid has factory wing. Whole chassis is for sale. It has a salvaged title but is repairable. It is great for a drift or track car. I will have a updated list with part prices later on today.
Have a great day,
Jared
Old 07-10-2013, 09:43 PM   #3
Reece
Reece's Avatar
Reece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymore
Do you have headlight surrounds?
Reece is offline   Reply With Quote
Old 07-11-2013, 12:06 PM   #4
tapdeznutz
tapdeznutz's Avatar
Trader Rating: (50)
tapdeznutz is an unknown quantity at this point
Feedback Score: 50 reviews
how much for the SS brake lines? text me 562.522.9340 and where are you located.
FS: DSS 1pc Steel Non ABS, 6bolt axles
WTB: Boost Gauge, Hatch Roof Wing
tapdeznutz is offline   Reply With Quote
Old 07-11-2013, 01:55 PM   #5
Jfornachon
I'll check on the headlight surrounds. It will only be the left if I do. The right is toast.
Have a great day,
Jared
Old 07-12-2013, 01:47 AM   #6
that_one_coupe
that_one_coupe's Avatar
that_one_coupe is on a distinguished road
Where in Socal r u and how much for the s13 Nismo Brace?
that_one_coupe is offline   Reply With Quote
Old 07-13-2013, 10:10 PM   #7
Jfornachon
I am in Canoga Park.
Have a great day,
Jared
Old 07-13-2013, 10:16 PM   #8
Jfornachon
This listing is closed. I have made a part out thread. Please check there for updated parts list.
Have a great day,
Jared
