Wobbling wheels
While driving, I noticed that my wheels were very wobbly. When I got home, I found out that all of the lug nuts were very loose. I guess I put too much oil to lube the rusty lugs....
Could I have loosened up some suspension parts due to driving with loose wheels? How can I fix this problem? Thanks Last edited by xXKoukiXx; 07-06-2013 at 10:55 PM.. |
![]() Feedback Score: 6 reviews
lift up the car and wiggle the wheel if the wheel is still moving but the suspension is solid then your lug studs/lug nuts are jacked which from the video is what I am seeing.
#6 |
![]() yeah bro, I think you should check your rotor and thread on the studs. you might find the problem there. because obviously you can ride around but not too fast. one of my buddies once rode around in his s13 hatch with three lugs only on the rear right tire because one stud was broken, then shortly after driving on the free way it started to shake real bad. so I say just take the wheel off and take a good look at it. also don't over tighten your lugs.
#7 | |
But I do remember that when I was installing the wheels, one of the rear rotors was a little loose even though the e-brake was engaged.... |
#8 |
Man w/ CTSV & a Car Seat
Did you torque the lugs down? What wheels are they? If you look on the hub, there a hubcentric ring in the middle, sometimes some wheels doesnt fit around it so it wont sit flush to the hub. That could be your issue.
#9 | |
The wheels are SSR Professor SP1s. I think the bore sizes are compatible as I see many S13s with these wheels. eg: ![]() |
#13 |
Over torquing a lug nut can do just as much damage. Do yourself a favor go to the hardware store and get a torque wrench. For the love of god do not get one at harbor freight.
What you need to do is take the wheels that where "wobbling" turn the wheel around to where you can see the backside of the wheel hub and inspect the lug holes. Make sure they are perfectly round. You might have caused the lug holes to become egg shapped which can cause a wheel to come off or crack in some points. Reference picture (this is not my picture just found it on google) ![]() |
#14 |
+1 for the hub ring issue also. Where did the wheels come from? Brand new order for a nissan hub bore? Or did you buy them used?
#15 |
#16 |
Put the wheel on. Jack the car up. Wiggle the wheel. Look at that brake rotor when you wiggle. If the rotor wiggles as well, you trashed the bearings because you didn't torque the wheel properly. This let the wheel wobble, pulling on the bearings... now you fixed the wheel, but the bearings are still trashed.
#17 |
^^^Thanks for the reply.
I figured it out. The wheels have hub rings on them that are too small. Below is a picture of one of my wheels, as you can see, there is a small hub centric ring. How do I take them off? Hammer and screw driver? Are these typically glued/melted on the wheel? ![]() Here is the same kind of wheel without the ring for comparative purposes: ![]() Thanks |
#18 | |
#19 |
![]() Join Date: Feb 2010
![]() ![]() Feedback Score: 20 reviews
If you aren't sure on how to remove a hub-centric ring, please be careful working on anything else on your car.
@MMyriad |
#20 |
#21 |
![]() Join Date: May 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 10 reviews
Check your studs AND lugs thoroughly when you put your wheels back on. A buddy of mine did something similar when he borrowed my wheels and damaged his studs and lugs.
#24 |
#25 |
![]() Join Date: Jun 2007
Trader Rating: (22)
![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
I haven't read through the whole page, but NEVER use oil on wheel bolts/nuts.
Clean and dry them. If you oil them, you create 2 problems: one, torque wrench is no longer corresponding with the service manual specs for dry torque value. When wet, they will tighten down more with less force. second, you risk them backing off on their own. This is info from number of factory service manuals. |
#28 |
Saw this thread and first thing I was going to say was hub centric ring even though I wasn't positive. Now I wonder why it didn't fit well. Don't SSR wheels come with rings? Looking for new ones now?
#30 |
