Old 07-13-2013, 03:50 PM   #1
Ryan_1
Ryan_1 is an unknown quantity at this point
What engine mounts to you use on a RB S14 conversion
Hey guys
Im doing a RB25 conversion in to my S14. I have a R32 crossmember and not sure what engine mounts are on the motor at the moment it came out of my S13 and used to rub the bonnet a little bit on the cam cover. Just wondering what engine mounts should I use to lower the motor a little more?
Thanks
Ryan_1 is offline   Reply With Quote
Old 07-13-2013, 05:07 PM   #2
Sileighty_85
Sileighty_85's Avatar
To make it fit the best you would need a R33 crossmember and a set of SYKO Mounts
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 07-14-2013, 06:35 PM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
You can't use an R32 cross member on an RB25 since the angles are off. Only way you can use is it is if you swap out the engine mount metal brackets for R32 brackets.
CLICK HERE!!!
Old 07-14-2013, 07:59 PM   #4
LMFC
LMFC's Avatar
LMFC is an unknown quantity at this point
I used the r33 xmember and the factory mounts. But if you can swing it I would use the syko mounts with r33 xmember.
LMFC is offline   Reply With Quote
