![]() Join Date: Apr 2013
Will I need a tune after building my head ?!
So I'm planning on building my top end. I'm just wondering if I'll need to tune my car after I install all my parts ( listed below ) running the stock T25 (Blacktop SR by the way ). I am going to upgrade to a gt2871 in the future but wanna know if i can run a built head in the mean time without a tune ?
Parts being installed: - Tomei step 1 256 camshaft - Tomei adjustable cam gears - Tomei RAS - Brian Crower valvesprings & Titanium retainers - Supertech Valves - Supertech valve seals |
![]() Join Date: Sep 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
If you are not going over-sized on the valves and the cam gears are set correctly, and a correctly sized head gasket is used? Then NO!
That's not really a built head now is it? ![]()
You can, but different cam profiles will change the air/fuel ratio at wide open throttle. You will want to tune the AFR and ignition timing to maximize the power you can get out of the head.
I would install the stuff you have now, get a 2871R/supporting fuel & software and get it tuned then, since at that point you will need to be compensating for larger injectors and so on. |
#5 | |
#6 | |
Poncams are drop in and with the t25 no need for a retune. Sent from a Highly Tuned SIII using Tapatalk HD
#7 | |
