Old 07-21-2013, 06:56 AM   #1
Huntsman2007
Banned from the Marketplace
Huntsman2007 is an unknown quantity at this point
Relisting! 400+hp rb25 s2 complete swap minus ecu! $4500!
RELISTING --sold apexi power fc. Will be a complete swap minus ecu. Trying to avoid parting out. 4500 takes it all!!! This is an awesome deal people!!!!!
Well I'm selling off all of my rb stuff from my collection to go turbo lsx. This motor pulls 160psi across the board. Compression test pics to back it up. The block and head are stock. Built block will be sold separately. Will also come with a stock trans, not the ppg trans. This motor has about 2k miles now in my car, maybe close to 3,000 now. Oil has been changed twice already. Head gasket, water pump, and timing components are all new. This will
Be every single component you need to put it in your car, fire it up, and make serious power. From the wiring harness, all the way to the fuel pump. Lets get the list started.
-R33 Rb25 s2- purchased from Japanese Motors Direct. Purchased roughly 8 months ago.
-Factory head gasket, timing compliments, water pump, all replaced at time of swap.
-Isis intake manifold, ported to match head.
-Sikky thermal intake manifold spacer
-super spark coil packs
-will install fresh Ngk plugs upon sale
-Jecs 555cc injectors, cleaned and flow tested with paper work
-tamioka fuel pressure regulator, with all fuel lines needed and tomei fuel rail adapter
-Pure turbos billet wheel 54/57 turbo
-McKinney downpipe
- hdmi front mount, with piping, and bung welded in for iat sensor
-mickinney mount kit
-Driveshaft shop steel driveshaft
-wiring specialties harness
-Walboro 255 will be included
-spec stage 3+ clutch.
I'm sure I'm forgetting a bunch of stuff, but this is a general idea.
Everything in this picture is included.
Last edited by Huntsman2007; 07-21-2013 at 06:58 AM.. Reason: Spelling and removed filler
Huntsman2007 is offline   Reply With Quote
